Discuss 15/22mm Benders in the Plumbing Jobs | The Job-board area at PlumbersForums.net
B
bustagut
Hi guys!
I doing my training at the mo and am compiling a list of tools for my kit and would like to know if anyone has advice on the best 15/22mm pipe benders to get hold of/prices.
Ive heard the Irwin Record and Hilmor are decent bits of kit but would like to know if anyone has any others in mind?
Thanks!!
Ant :confused:
very rare you will use the benders, i do alot of bathrooms and wetrooms and there is no room to work with the benders unless you do the bending in another room or outside but i do make pass overs in my garage then chop them of and solder them on site
I install heating systems and use Hilmor tube benders EVERY day, good bit of kit, currently around the £60 mark
Keith.:cool:
I make up 90 45 deg bends and crossovers in 15 & 22mm and leave in box until needed, join as required, saves time on the job if there's not much spacce.
John
The good thing about the Hilmor bender, compared with others, is that it has a deeper 'throat' between the roller and the former (quadrant), so you can extract the bent tube much easier!
Just an observation!
hilmore i find are the better benders on the market and easyer to use for some reason
bought mine for £50 of good ole trusty ebay
i love my hilmor, floor standing benders, always a nice curve, very rare to get a ripple like ive seen so often with the rothenburgers.
missus complains a bit tho, when i send her to lag one of my plantrooms full of 35mm bends!
saves a foretune on fittings, but missus labour costs are on the rise so maybe i shall use an elbow or two on the next one!
shaun
I have used Hilmour, Record and Rothenberg but did not find much difference really.
I have got a set of Hilmour and Rothenberg that where on special offer in the Plumb Centre some years ago.
What seemed good about them was that they bent 22, 15 and 12mm.
Err Lost the 12mm guide and can't find one now!
Mind you what do I want one for anyway, I'm retired now! :)
Hi
I about 5 months ago I bought I Sealey or a Stanley 15mm pipe bender. It’s small enough to go into you tool box. Thought is would be rubbish but gave it a go, now it never leaves my toolbox. I use it all the time, because it’s so small. I would recommend one.
just adding to what everyones already said, hilmor are a very reliable and good quality set, I do find I will try to leave them outside in van until needed if space is tight but still you will need them on a regular basis
I had a cheap unbranded bender and although it bent 15mm okay, it was near impossible to bend the 22mm it just took silly ammount of effort but thats what happens when you buy gear on the cheap you normaly have to buy it again.
I got a Irwin Hilmore bender from [DLMURL="http://www.ukplumbersforums.co.uk/redirector.php?url=http%3A%2F%2Fwww.bes.co.uk%2F"]B.E.S Ltd, Plumbing and Gas supplies[/DLMURL]
Part number 7762 for 48 quid VAT included. Works like a dream on both 15mm and 22mm and its highly recomended, they can save you money in fittings and I use mine all the time in alsort of scenarios. Good bit of kit.
Record benders are the most reliable, only problem they have been bought out by Monumount and they not as good.
If you see a second hand pair of Record Benders BUY THEM...!
Had a lot of problems with Hilmor marking pipe, bad formers, etc.
Reply to 15/22mm Benders in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, My current hot water system needs to be replaced. Anyone got any suggestions or can recommend any plumbers around Derrimut area that won't...
Hi all Noticed bad smell in my drain out side put my hand down and it unclogged it for now however I checked my sewer drain and after flushing my...
