Discuss Hot flow and return pipes, hot upstairs rad but cold rads downstairs in the Plumbing Jobs | The Job-board area at PlumbersForums.net
As in the title, the flow and return pipes both get hot when the heating is turned on, yet only the upstairs radiators get hot.
I am very puzzled by this. Even turning off all thermostatic valves upstairs, none of the downstairs rads get hot. Our plumber says there must be a blockage looking for a second opinion. Not sure how there can be a blockage if the return is still hot.
Any help would be appreciated.
Mark
sorry mark
thanks for deleting the spam mate, some people really have nothing better to do!
it gets frustrating trying to kock them back two more pop up
right back to business how fast does the temp rise on the boiler?
could be pump stuck happens with the new eco pumps but need to be gas safe to have a look
Possible but could be a few other things that I am not allowed to tell you how to check. (Sorry)
No worries, it's just the boiler has a warranty but I don't want our plumber to try and go around it by blaming the problem on our pipes.
We haven't got much experience with them so still building up trust so don't want to be given the run around hence asking on here.
get Vaillant out there have a decent set of lads
Your first point of call should always be your gas engineer. But if you have lost faith then go straight to Vaillant. They are generally really helpful and if you have warranty they will come out and have a look.
Hmm, I could time it, what time frame should it be?
May have underestimated it last time, time flies when you're having fun staring at a temperature guage
if it shoots up and doesnt go down within 2-3 mins and boiler doesnt stay lit (fired) then i would say pump could be stuck
Right, just tried again. After turning the thermostat up, temp rose very quickly to 57, then dropped back down to 50 (sounded like pump turned on), then was fluctuating from 55-50 after 1 minute.
After 3 minutes its 57
4 minutes its 59
5 mins its 62 (boiler still fired)
7 mins in its 66
So, does seem to be rising slowly.
I am heating a click sound every so often (every 10-30 seconds) not sure if that is important.
i would say thats fine then
Reply to Hot flow and return pipes, hot upstairs rad but cold rads downstairs in the Plumbing Jobs | The Job-board area at PlumbersForums.net
