Discuss How to identify dripping tap. in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Which one do you use most ? Or change both as same age
I appreciate thatShaun but how do I isolate the blinking thing, there are no stop cocks in the supply pipes!!
Turn the water mains off ?
Might run for 5 mins so leave it open eg tap for 5 mins
Turn stopcock off. That should stop cold.
If you’ve a combi boiler, turn it off, the cold stopcock will also stop the hot. Open kitchen tap hot and cold, then open upstairs bathroom hot and cold. Water will stop after a min.
If you’ve got a hot water tank. If an unvented/mains pressure, same as above.
If gravity, fed from loft tank, you need to isolate the cold feed to the cylinder. Either valve near cylinder, or in loft on cold feed to cylinder pipe.
Thanks Timmy. We're a bungalow so ours is a totally closed system, heated from an Air Source Heat Pump and pressurised by the mains water pressure I guess . Cylinder in airing cupboard.
If I turn off the mains I guess it will take quite a while for the system to de pressurise and stop flowing.
If I'm going to do that I will try to fit stop cocks in each tap supply line but they are very tight against the back of the fitted kitchen cupboard they're in.
Or use these if your new tap comes with swivel flexis
Thanks everybody for the help, job done. The problem was that the mains shut-off valve was sticking, not shutting completely. Moved it on and off a few times and it sealed properly.
With water off and pressure released, installed two isolating valves in the kitchen taps so can now repair one or tother!
Can you turn off the supply to just the cylinder, then open hot tap to drain hot system.
If it continues to drip, its the cold.
Either way, i always replace cartridges in pairs.
Good job, in future, use full bore lever valves with a packing nut. Whenever I have to use these screwdriver valves, theres a 50/50 chance it will leak and need replacing.
Reply to How to identify dripping tap. in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I have a Bristan Manhattan mixer tap in the kitchen. Five years ago, it started to drip. I replaced the valve in the cold water side and the...
Hello all, first time poster so if there is any additional information I can provide that may help, please let me know. Our kitchen mixer tap has...
I had an outside tap fitted by a professional plumber last autumn. During the recent cold weather the feed pipe under the kitchen sink froze and...
Hi. I have a kitchen mixer tap unit with older washer type inserts which has a dripping cold side. I have a pair of replacement ceramic inserts to...
We have just moved in to a 1934 Semi- and I am getting round a few simple DIY tasks, including a couple of plumbing-part renewals such as modern...
