Discuss Boiler losing pressure only on central heating in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi, I have a Worcester 28i junior boiler that has started to lose pressure, only when using the central heating. When using hot water I have no issue, however, when running the heating the pressure drops. Im looking for some ideas on what could be causing this. I have no sign of pipe leaks, although they could be hidden. Is it possible it could be the boiler, even though I see no water leaks?
Expansion issue so needs a gas safe engy to fix as the prv will need to be changed
Hi. I was hoping it would be something along those lines rather than a leak. With it only being when I used the heating I was convinced it was a pipe leak and currently see not water anywhere. Was worried it was hidden somewhere. Would I expect to see water coming from the over flow in this case or not? Thank you...
Maybe but only when the system is fully hot
Also, the pressure increases to 3 during the heating cycle. It did then come down again.
Which probably would the prv letting some out or it cooling down
Reply to Boiler losing pressure only on central heating in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Good afternoon, I am experiencing a pressure issue with my heating system and was hoping to receive additional insight as to what the problem...
Hi all not a plumber but am an engineer I have pressure drop in the system Worcester Bosch came back after repressureising the expansion vessel...
Can central heating / gas engineer expert help me with below issue. During winter time only, I have been having issue with low pressure or...
PSxxxxxx
I have an 8 year old Potterton HE Gold combi boiler losing pressure. I have isolated the central heating to leave just water heating and it is...
