M
mredd
Yes, as you have shown with the arrows. You would stop short of cutting through the thred. You could finish the last bit with a junior hacksaw.It will break off ok with a good twist. Not too much heat, just enough for the remainder of the elbow to expand and loosen it's grip on the vertical.
If there is enough room for the elbow to turn without hitting the wall you can try with stillsons but you can run the risk of making the joint in the floor leak.
If it does go wrong, as you say use the philmac fitting.
