Discuss Y-plan valve causing boiler shutdown when switching positions in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have a Y-plan 3 port valve in my system, no idea of make, it's been installed for a number of years has been working fine, but now I've had a new boiler fitted it seems to be a lot more sensitive to temporary interruptions in flow, e.g. when the valve switches between mid position and heating only, the boiler shuts down for a few minutes before eventually firing again.
I suspect it's because when the valve is turning it momentarily shuts off the flow to both mid and heating ports - my question is would a newer valve solve this (i.e. are modern valves designed not to interrupt flow whilst turning)? Or would a bypass solve this (I don't have one)? Or should I just not worry about it?
nope thats how 3 ports work best option is switch to an s plan system
The increased off time will be an anti cycling feature of the new boiler. It won't be the flow but a momentary interruption in run signal to boiler.
Is this behaviour normal on a Y-plan system?
Would prefer if the boiler stays lit whilst the valve is switching, but doesn't sound like there's a lot I can do about it.
Yes normal
Other than s plan
Reply to Y-plan valve causing boiler shutdown when switching positions in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Customer complained of hot water tank getting hot when no demand Y plan system couldn't see any issues so I watched it Timer set to CH only, HW off Thermostat turned to on Heating comes on as normal, valve moved to CH position After around 20 minutes the 3 way valve moves to mid point and...
2K
Customer complains of Intermittent heating on Y plan with Stat satisfied. New boiler fitted last year (no permanent live required or fitted previously) on an existing Y plan system. Existing timer was a Randall 103 (no hot water off position as its a timer not a programmer). The customer wanted...
2K
 Our heating stopped working today. We've got a Veissmann boiler that's under a year old, and an older Megaflow cylinder, and two diverter valves (all about 10 years old). We also use a Hive thermostat.
 When I boost the hot water with Hive, the receiver near the boiler shows it's...
Hello I have a NEST with Viessmann system boiler with unvented cylinder. I have a mid position and two position valve I thought the mid position valve was faulty as it was not switching off I got new actuator - the right one (40003916-003/U) . The manuals do make a reference to v4073a1039...
Hi, I have just installed a Tado system with the Wireless Reciever and Two Smart Thermostats. Without getting into the weeds of Tado, I want to energize the CH system all the time. But Why? I have two thermostats which control a demand valve each which when opened kick the boiler and the...
