Discuss Worcester RD532i --------NEST WIFI thermostat in the Plumbing Jobs | The Job-board area at PlumbersForums.net
K
kjb1
Hi all, I am in the process of looking to upgrade my thermostat to a Nest wifi stat. Can anyone let me know whether they have succeeded in fitting one to this style boiler? my current programmer / stat has 3 wires into boiler ( low voltage), I am aware the nest is only 2 wire 240v switching.
Can anyone confirm this Nest will work with boiler mentioned, much appreciated if so?
The heat link needs a live & neutral 240v, plus switch wires to the boiler this is normally adjacent the boiler... the nest stat itself can be fitted to a power socket nearby with a 12v power cable
Hi thanks for the reply. I am aware of the 240 to power heat link, and the switch out to the boiler for call for heat etc, it's more so to do with my boiler, as i am reading that this style boiler will talk to a manufacturer only thermostat, anyone have any info on this? and whether there is a work around?
thanks again
Reply to Worcester RD532i --------NEST WIFI thermostat in the Plumbing Jobs | The Job-board area at PlumbersForums.net
