Discuss Worcester Heatslave 15/19 enquiry in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hoping someone can answer this query. I am going to replace my expansion vessel on my Worcester Heatslave 15/19 oil fired boiler. I am fairly happy with most of the process my only query is within the instructions it says at the beginning to withdraw the boiler to prevent water ingress. But there is no further explaination as to how to do this. Advice would be appreciated.
I am assuming you mean it said to withdraw the BURNER?
That would be to prevent water falling on top of it and into electrics.
Problem is if you remove the burner out a bit, you will then be pulling on the oil hose connected to it and this can leak.
Also electrics need isolated.
Really a job for an oil service engineer to do. The new vessel gas precharge should be checked and kept in relation to system pressure.
It would be possible to remove the vessel carefully without pulling burner out, but would need old towels and plastic cover over burner area.
The old vessel will be extremely heavy if the membrane has ruptured and entire vessel full of water!
Best- thanks for responding. I did mean withdraw the burner it was a typo.
Coincidently, today I serviced an oil boiler and moved the burner out and back in place carefully.
Then discovered the not particularly old oil hose had begun to leak and had to replace it
Reply to Worcester Heatslave 15/19 enquiry in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Folks I'm wondering anyone here, has any indepth knowledge on the Worcester Heatslave Combi Boiler. This boiler is quite old (2006) but it has been very reliable, and also runs at superb efficiency when tested, regularly serviced etc. The boiler is in a very old stone cottage (built 1791)...
M
Hi all. I have a 20 year old Worcester Bosch Heatslave 12/14 Oil-fired I'm getting about 20 seconds of hot water, then the boiler won't fire. I can crank the HW dial right up and it'll fire and give me another 20 secs of hot water. It won't fire again with demand from the tap. It was losing...
Hi hoping someone can help with this as its beginning to drive me nuts. Boiler generally well serviced and working fine, no problems with DHW. Central heating recently began to occasionally fire up as normal and run until it reached temperature set by flow control thermostat at which point...
Hi new to this forum, hope someone will have the answer to my issue. I have Recently had a new Diverter valve brass body and motor replaced on my 15/19 Worcestershire heatslave oil boiler, due to the old one seized. Since this i have had issues with the water pressure in the boiler it drops to...
2K
Hi I have an oil worcester bosch greenstar heatslave ii combi boiler. It's about 5 years old. The problem I have is when the thermostat calls for the central heating to come on. Most of the time the boiler light will come on, the boiler might fire up for a couple of seconds then the light will...
3K
