Discuss Worcester Bosch filter fitted too high? in the Central Heating Forum area at UKPlumbersForums.co.uk.
  1. Andy Slack
    Andy Slack New Member
    I have had a new 32 CDi Compact WB boiler fitted recently,along with a Greenstar filter.
    The filter has been fitted very high up, about 4-5 cm from the ceiling. Watching youtube videos, it seems the lid has to be unscrewed and the filter lifted out from the top. Can the filter be unscrewed (top and bottom) instead and removed this way when servicing the boiler? I don't want to find the warranty is invalid as the boiler can't be serviced in 12 month's time.
    Also, should I (a homeowner) be able to remove and inspect the filter or is a corgi registered engineer required to do this?
    Andy
  2. SmokeyJ
    SmokeyJ GSR
    You can remove the whole filter and clean out if there isn't enough space to get the magnet out, just more of a pain in the arse to do so.
    A homeowner shouldn't need to inspect the filter.
    They never really get that dirty tbh unless the system wasn't sufficiently cleaned prior to the install. So once a year with the boiler service is normally adequate.
    You don't need to be 'gas safe' to clean one, just a basic understanding of the system. I.e making sure pump and boiler are off before isolating it.
    • Like Like x 1
  3. Andy Slack
    Thanks SmokeyJ, that's a big relief to know.
    Regards
    Andy
  4. ShaunCorbs
    Not the best but better than not having one fitted
  5. scott_d
    scott_d Plumber GSR Top Contributor!!
    Can you post a picture?
    • Like Like x 1
  6. Rob Foster
    Rob Foster Top Contributor!!
    Just out of pure professional interest what made you choose a Worcester Boiler ...Rob Foster
    centralheatking
  7. Rob Foster
    Your GSR installer should have fully informed you of all aspects of your installation before you signed it off and then you pay the final balance etc. However this is one of the reasons UkPF
    is so good Rob Foster aka centralheatking
  8. Andy Slack
    This is the filter
  9. EvilDrPorkChop
    EvilDrPorkChop GSR
    You could have got that another 10cm lower which at that point I'd suspect you'd get the lid off and the filter section out.
    TBH wrong filter for job. Needed something different if it was going above boiler.
  10. Rob Foster
    That is daft , Centralheatking
    Any residual water will go all over the boiler
    hall of infamy for this one uck
    • Agree Agree x 1
  11. Craig Watson
    Craig Watson Plumber GSR Top Contributor!!
    Don't Worcester specify their filter for the extended warranty though? Or do they do different versions?
    • Like Like x 1
  12. scott_d
    Yes
    • Like Like x 1
  13. EvilDrPorkChop
    EvilDrPorkChop GSR
    Don't fit Worcesters so don't know, however I have read somewhere they now do a compact one?
    TBH I won't fit anything other than Adey for filters.
  14. Craig Watson
    Same here, I haven't fit a Worcester in 4 years and always stick to the adey filters. That's another plus for baxi, they don't specify a filter just so long as you fit one.
  15. Harvest Fields
    Is that attached to pushfit connectors?
Loading...
Similar Threads - Worcester Bosch filter Forum Date
Worcester Bosch Heatslave Green star 18/25 continuously locks out Oil and Solid Fuel Forum Apr 29, 2019
worcester bosch heatslave 15/19 oil baffle arrangement Oil and Solid Fuel Forum Apr 26, 2019
