Discuss Wiring help to Hive controller in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all,
I am after some advice regarding an issue after a Hive Dual Channel install.
I have installed the Hive system to my gravity fed HW and pumped central heating system and it works fine, water comes on as requested and the pump comes on when CH is selected.
The issue I have is that the system is a Baxi Bermuda back boiler and gas fire and I now cannot get power to the fire.
The boiler has a built in thermostat for the water temp, which I have just turned up to full.
I have wired up the controller backplate as follows:-
Permanent Neutral - neutral from 3 amp spur, plus neutrals for boiler and pump.
Permanent Live - live from 3 amp spur
3 - Live to boiler (HW on)
4 - Live to pump (CH on)
There is no electrical power to the gas fire, which means we cannot light it up.
Would it be as easy as linking the permanent live to connection 3 (live to boiler), as we only ever have the fire on when the water is on anyway?
Thanks in advance
Reply to Wiring help to Hive controller in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I’m looking to install the above. Atm I have an older one fitted (old wireless thermostat and old receiver that’s wired into my combi boiler. Pic below shows how my current one is wired, live neutral and would the 2x black wires be switch wires and would matter what way they were wired in? My...
I have an issue with a Worcester Greenstar 29CDi Classic boiler. I replaced the old thermostat controller with a smart dual-channel HIVE one. I did all the wiring following the diagram in the attached picture. The boiler doesn't work anymore. Please, any suggestions?
Hi, I am trying to link a Hive heating & hot water dual channel receiver to an old Vaillant THERMOcompact VU GB 242/1 E system boiler. It has an internal programmer that is similar to a time switch 120 (plug in seven day programmer) This programmer is connect to a terminal strip using 345 (three...
 Our heating stopped working today. We've got a Veissmann boiler that's under a year old, and an older Megaflow cylinder, and two diverter valves (all about 10 years old). We also use a Hive thermostat.
 When I boost the hot water with Hive, the receiver near the boiler shows it's...
Hi all. So I have just moved into a new house with a Potterton boiler in it. Great big thing!! lol. I want to fit a Hive to it but it obviously doesn't have a separate standard control box to just switch over like my last one owing to the internal timer etc. Inside the main unit is the...
1K
