Discuss WiFi Thermostat Installation in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Please can someone help before I knacker the boiler, we have just moved in our house and there is a Worcester Greenstar Heatslave 2 oil combi boiler. It already has an old dial thermostat which apears to have Live, Neutral and Earth wired into it, I would like to change for a WiFi one, the Wifi one is a Beok style do I just swap it out and put the Live and Neutral In the corresponding inputs on the Wifi but I've also read that a SL? needs incorporating somewhere on the new WiFi thermostat is this correct please and if so where and what do I need to do thanks 8n advance....Cheeers Chris
BT Cloud
BT Cloud
BT Cloud
Reply to WiFi Thermostat Installation in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I live in a really remote part of the Highlands, so paying for a plumber (or electrician?) to do this will be brutally expensive, so I need to do it myself. I have a Grant Combi 26e boiler. I'm replacing the old thermostat with a new one. Although the boiler is a combi, I think the old...
We have recently moved into a property which has a Worcester Greenstar Highflow 440 Standalone Combi gas boiler. This appears to be a relatively old unit however, it is still in great working condition and has been serviced on a regular basis. I'd like to add a Nest Thermostat to control the...
I would like to install a Energenie MiHome Smart Thermostat, it has 2 wire inputs W and COM, my existing thermostat has 3 wires a red live, yellow (Not sure) and a blue wire that is connect to the earth for some reason. it is an old Altech thermostat. Does anyone know were the wires would go on...
I am going to replace my existing heating system controls with a wireless smart heating system (probably Drayton Wiser). In doing so I want to remove the two existing room thermostats I have (I have two zones for my central heating). They both have three wires (as well as the earth) black...
3K
C
Ive moved into a house with a worcester greenstar 35 HE plus boiler in the garage. The TR2 thermostat controller is hanging loose on the wall in the living room, and is faulty. I want the TR2 replaced with a controller i can set a timer on, either digital or mechanical, the TR2 has three wires...
2K
