Discuss which thermostat? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
W
will777
Hi all,
I am having a new worcester 30cdi boiler fitted and im wanting a 7 day programmable thermostat to replace the old dial thermostat there at the minute however i have 2 questions.
1. Am i right in thinking the old wiring will not be sufficient to run the new thermostat so i will need a wireless one?
2. Can anyone suggest any good thermostats as there are so many to choose from? Its only a semi detched so there is no zones to heat and so something relatively easy to use, im thinking touchscreen prob look bling but are they any good?
Any info much appreciated!
I am having a new Worcester 30cdi boiler fitted
Combi, System or Regular?
How many wires go to the thermostat - excluding earth?
Most thermostats run on batteries, so you only need two wires, Live and Switched Live.
Is the existing thermostat in the best position to control the heat? If it is you should not need to go wireless.
Honeywell CM907 (wired) or CM927 (wireless)
Hi
Thanks for your reply.
Its a combi boiler, there is 2 wires excluding the earth and it is situated in the hallway which i think is the best place for it so wont need relocating.
Then you can use a Honeywell CM907 with the existing wires. The boiler installer will connect it up for you.
Reply to which thermostat? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Can anyone advise as to why the cold water to my bathroom keeps airlocking? This originally happened about 12 months ago and has happened 3-4 times since. Itā€™s an upstairs bathroom, fed from a tank in the attic. The tank is about 8 Meters away and feeds a bath, sink and toilet. The tank...
Hello all, Iā€™m replacing a concrete paving slab patio in the back yard. The original patio used 50mm deep concrete slabs on hardcore & sand. Iā€™m planning to pour a 100mm deep concrete patio on 100mm hardcore. In order to achieve the same final height to line up with the rest of the patio, I...
