Discuss Where can I get the right size bleed key? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have some Pegler Terrier lock shields with drain off capability. A standard bleed key is too big as it appears they use a smaller square head on their valves.
Anyone know where I can get a bleed key to fit.
Graham
I don’t know where the other post is, but is it a drain off you want to open, or bleed the rad? The valves will have no effect on the bleeding of the radiator, unless they’re shut of course.
It was to undo the drain tap on the lockshield valve, not to bleed the radiator. Problem solved now as I have found the right size key thanks.
Reply to Where can I get the right size bleed key? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
