Discuss What is this called that I need to replace in my shower? in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
Tags:
  1. alichambersUK
    alichambersUK Member
    Hi - I'm replacing a leaking guttering type seal in my shower.
    What is the part called that I need to get, circled in red?
    Thanks.
  2. Mastermixlee
    Mastermixlee GSR
    Goes by different names based on brand/website. But generally you'll find it by searching for bath/shower quadrant seal
    • Like Like x 1
  3. Harvest Fields
    And I wouldn’t use any of it. Raise the shower tray and silicone it properly.
    • Agree Agree x 2
    • Like Like x 1
  4. townfanjon
    Your local UPVC roofing merchants will stock it .
  5. Andy duncan
    Andy duncan New Member
    As previous, raise it and silicone the tray, it will give a better result bud.
  6. Mastermixlee
    Mastermixlee GSR
    Whilst it will give a better result raising it. Personally I wouldn't bother in this instance. Don't think it's worth the upheaval to keep that kind of shower tray setup and muck about with pvc trim that would be needed on the sides to cater for the increased height etc when they're only trying to reseal worn/poorly installed trims.
    If it were a new bathroom or replacing the shower tray then definitely, but if op is just trying to keep water tight etc then sealant with the trims will be fine.
    • Like Like x 2
    • Agree Agree x 1
  7. alichambersUK
    Thank you for all of your suggestions. Every one of them is useful to me.
    My preference is to use the quadrant as raising the tray would be a much bigger job.
    Such a good forum this. I've had a lot of help from it.
    • Like Like x 2
    • Friendly Friendly x 1
Loading...
Similar Threads - called need replace Forum Date
What do I need and what would it be called? Bathrooms, Showers and Wetrooms Apr 22, 2019
vertical waste pipe is 235mm from wall, need a WC to accommodate this Sanitary Ware Friday at 4:04 PM
