Discuss What is causing this sound? in the Plumbing Forum area at UKPlumbersForums.co.uk.
  1. Cyrus H
    Cyrus H New Member
    Hi all,
    Can anyone identify this sound and what is causing it? It's coming from the boiler flue, and happening intermittently (maybe every 10 minutes or so). Sometimes it comes out as short bursts, other times it can be up to around 5 seconds, but the sound is the same.
    Cheers everyone!
    C
  2. Harvest Fields
    Are you Gas safe registered? What make and model of boiler is it?
  3. Cyrus H
    Cyrus H New Member
    I'm not a professional plumber, but this is coming from my neighbours boiler - they have arranged a plumber recently but they did not manage to find any faults. I'm unsure what model it is. Cheers
  4. Harvest Fields
    Are they private apartments or all the same landlord?
  5. Cyrus H
    Cyrus H New Member
    Private apartments but rented out. I am also starting to wonder if its illegal for them to have the flue that close to a vent (I believe its for cooker extraction). They have been very unhelpful - I even offered to pay for a plumber at my own expense but now they say that the boiler is under warranty so only the boiler's company engineer can inspect the boiler - which will be over a month away...!
  6. AMGasServices
    AMGasServices GSR
    It looks like a Baxi.
  7. garygvl
    garygvl GSR
    sorry but youll never have to wait for a month for a warranty call from a manufacturer
  8. townfanjon
    It may not last a month lol
  9. ShaunCorbs
    Not installed correctly due to vent
  10. Riley
    Yep not installed to spec. Difficult to do anything if they won’t let you in though
  11. townfanjon
    I would think your neighbour is telling porkies , most if not all manufacturers will be out within a few days to fix one of their boilers , assuming it is registered of course ??????
    • Agree Agree x 1
  12. garygvl
    garygvl GSR
    apparently i cant contact you due to your privacy settings
  13. Harvest Fields
    Click on the contact button below my icon on this post.
    Edit- I have sent you a PM
  14. Riley
    Are you chasing your Gs forum membership.
  15. garygvl
    garygvl GSR
    no just making the point it wouldnt let me contact harvest who i did try first before you, nothing personal
    • Like Like x 1
Loading...
Similar Threads - causing sound Forum Date
Caleffi Pressure reduction valve causing noise Plumbing Forum May 19, 2019
Wear And Tear Causing Leaks? Plumbing Forum Apr 28, 2019
