Discuss WC won't stop running in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
Tags:
  1. RED2
    RED2 New Member
    Photo attached if inside of cistern. Water just keeps running into bowl and won't fill cistern.
    Water inlet seems fine - I think the problem is the seal between the main siphon (?) unit and the lower part of the cistern. If I move the unit slightly (its pretty secure) the leak can be made to stop and the cistern fills. Is there an easy way to repair this?
  2. Ben-gee
    Ben-gee Plumber
    you got it right probably, replace the seal on the flush valve.
  3. Rob Foster
    Rob Foster Top Contributor!!
    I think that your unit is a quick twist and release siphon,so do just that and get a replacemant one with new bottom washer (he he) but from a plumbers merchant on Monday ...take old one with you
    Don’t do Q&B tooooo expensive & crap
  4. Lewis Lawson
    Lewis Lawson New Member
    Fluid master in my opinion is the best siphon
    • Like Like x 1
  5. rpm
    rpm Trusted Plumber
    Twist and release, if rubber washer on the bottom is dirty then clean it and the mating surface and refit.
    If washer has bubbles on the surface then many can be reused with the opposite side of the rubber face.
    Total cost £0.00p :cool:
    • Like Like x 1
  6. RED2
    RED2 New Member
    So I just twist the unit anticlockwise to remove it or is it secured with any clips?
  7. king of pipes
    Twist to unlock then pull . Kop
  8. rpm
    rpm Trusted Plumber
    Look carefully and you will find 3 locating lugs, believe most go clockwise to release.
    • Like Like x 1
  9. Rob Foster
    Let us now how you get on please Rob Foster aka centralheatking
Loading...
Similar Threads - won't stop running Forum Date
Brand New Saniflo Macerator Won't Run Plumbers Arms Thursday at 9:05 PM
He24 - removed rad now won't work at all New Member Introductions May 13, 2019
