Discuss WB Greenstar 30si Leaking in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All
Nipped over from the tilers forum but as you can read, my boiler is leaking.
It is a pinhole coming from the plastic flow unit and I was wondering if this was going to be expensive to repair if it can be fixed at all.
Any help would be most grateful.
Very easy fix but requires a gas safe engy as you need to remove the case
Left hand hydro block also best to fit a shock arrestor to stop it happening again
Reply to WB Greenstar 30si Leaking in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, i hope somebody can help me, i seem to have a leak from my GreeStar 30si boiler, it looks like it coming from the Siphon container, from the top, around where the Flue meets it, inside the boiler, i have noticed that there is an overflow pipe, yet, it seems that nothing can flow out the...
Hi, I need some urgent advice. I've Just come home after going out for evening, to discover hallway floor and kitchen floor covered in water. On further inspection I discovered that water was coming from boiler cupboard. On looking in boiler cupboard I found boiler has started leaking water...
hi all, i need help to fix the leak from a pipe connected to the water pump via flexi pipe and it is feed from the immersion heater. I have emptied the water tank in the loft and also closed the main stopcock. still the leak is on - hoping it will eventually stop. I have not idea how the...
Not exactly a plumbing problem but here goes. I have known for a couple of years there was a water leak somewhere between the water meter, on our property, and the property itself. The water company fitted a new (smart) meter about 4 weeks ago. Now they have contacted us saying we have a leak...
1K
Hi all, I have a couple of leaks coming under shower tray downstairs. One is along the wall so think might be joint between wall and tray and the other seems to be near waste tray, there is a slight hairline crack in shower tray near waste . This happens when I leave the shower head near the...
