Discuss Washing machine waste pipe in the Plumbing Forum area at UKPlumbersForums.co.uk.
  1. Badkin
    Badkin New Member
    Got to plumb outlet from washing machine into open vertical length of 110mm plastic pipe at floor level. Any suggestions for best way of doing this? Presume I'll need a trap? Use 40mm stand pipe and u-bend? How best to join to 110mm and cap the 110 pipe?
  2. Badkin
    Badkin New Member
    Do these adapters work?
  3. ShaunCorbs
    Yes they go into a fitting tho
    Or you can use a strap on boss / mechanical boss
  4. bogrodder
    bogrodder Plumber GSR
    You say an open vertical pipe, can you be certain it’s not a vent pipe for the drains? Or is just a short piece of waste doing nothing, if so is it connected to anything?
    These questions need to be thought of
    Cheers
  5. CBW1982
    CBW1982 GSR Top Contributor!!
    A photo at this point might be useful, to try and determine exactly what it is. If it’s open, then why? Was there one there before and you’re renewing?
  6. Badkin
    Badkin New Member
    Yes. It was put in byoriginal plumber at first fix and planned as washing machine outlet. Appreciate the warning though!
  7. Badkin
    Badkin New Member
    Thanks!
  8. Badkin
    Badkin New Member
    New extension. Pipe put in by original plumber with washing machine in mind. No photos sorry - too dark - but just looks like 75mm of 110 pipe coming out of [email protected]
    • Like Like x 1
  9. CBW1982
  10. Badkin
    Badkin New Member
    • Like Like x 1
Loading...
Similar Threads - Washing machine waste Forum Date
Underground wet washing machine waste Plumbing Forum Apr 29, 2019
washing machine waste pipe Plumbing Forum Apr 14, 2019
