Discuss Wall-mount mixer tap - lukewarm in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. PeterP
    PeterP New Member
    Hi all, I'm new to the forum
    I have a wallmounted theromstatic bar-type shower in a house I bought 5 months ago. The water coming out of the shower gets barely above lukewarm - if I twist the thermostat for the heat _at all_ the water goes cold.
    The bathroom sink taps (and throughout the house) work fine, otherwise.
    Do you think I need bar or can it be repaired?
    Thanks!
  2. scott_d
    scott_d Plumber GSR Top Contributor!!
    Has it ever worked
    • Like Like x 1
  3. Craig Watson
    Craig Watson Plumber GSR Top Contributor!!
    When you run the bar shower, turn it to full hot and put your hand on the left side inlet, does it get hot?
    Also what system are you on, gravity or mains?
    • Like Like x 1
  4. PeterP
    PeterP New Member
    Yes, it worked for the first couple of months.
    The hot water inlet isn't so hot that you can't touch it. You can comfortably keep your hand on it.
    System-wise, we have a combi boiler on the floor below, so I guess it's mains?
  5. scott_d
    Is it a branded shower?
    Can you find instruction online
    • Like Like x 1
  6. Craig Watson
    First thing to try would be the mesh filters on the inlet, turn the water off and open both the hot and cold taps downstairs. Take the valve off the wall and check the filters. If they are clear then it would point to the thermostatic cartridge. If you know what make and model the shower is then a replacement cartridge can be bought but if it's only a cheap bar mixer, you would be better off replacing it all.
    • Like Like x 2
    • Agree Agree x 2
  7. PeterP
    PeterP New Member
    It's not branded, as far as I can tell. I will look through the manuals previous owners left us, to see if there's anything there. I do know that it was fitted about 5 or 6 years ago.
    Thank you both for your help!
  8. Harvest Fields
    Any pictures.
    • Like Like x 1
  9. PeterP
    PeterP New Member
    Hi
    Pictures attached
  10. Stigster
    Stigster Plumber
    • Like Like x 1
  11. PeterP
    PeterP New Member
    That definitely looks like the one!
Loading...
Similar Threads - Wall mount mixer Forum Date
Have I enough space under window for wall mounted or back to wall toilet Bathrooms, Showers and Wetrooms Jan 21, 2019
PRV discharge pipework rendered into the wall Plumbers Arms Mar 4, 2019
