Discuss Vitodenns 050 29kw poor flow rate. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
Aire
Hi guys.
I'm not familiar with viessmann at all but I'm fitting a bathroom and customer has mentioned poor flow rate from the hot water. The cold is perfectly fine but the hot is really poor. I've checked the cold inlet valve on the boiler and that's fine. I've looked through the manual but can't find anything. Is there a flow restrictor within the boiler that can be adjusted?
Reply to Vitodenns 050 29kw poor flow rate. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Could I ask for some help with a water flow rate problem. I have good mains water pressure on the ground floor. There is no tank in the loft but an unvented cylinder in the upstairs airing cupboard. A gas heat only boiler. Upstairs I have two en suite rooms. One with a shower and one with...
Hello, I have quite low flow rate for my electric shower (a piddling 5L/min), and would like some tips or advice about how to solve or find the cause. I would like a flow rate of about 12L/min. Here is my set-up: Standard gas boiler (not a combi) in the kitchen, have cold water tanks in the...
Essaboy
E
Hello, First post, be gentle! Anyway, here's my issue. I have a Roca The Gap D-Trit close-couple toilet with integrated macerator in my secondary bathroom. In all it's a great solution for a problem location for a bathroom. However, the cistern has a typical european style side inlet pipe, and...
I'm having a nightmare trying to find matt black wall or deck mounted bath mixer taps with 3/4 fitting that work on 0.2 bar. From tank to tap, I have around 2.4 metres, so a pressure of a little over 0.2 bar. The flow measured from the tap currently fitted is 11 litres per minute. Pretty much...
  • Locked
Hello, I have a ferroli falcon 2 boiler (yes it is pretty old). A few days ago the hot water started going hot and cold when running. Monitoring the boiler, the demand light works fine. When the water gets up to temperature every 10 seconds or so, the boiler stops for a fraction of a second...
