Discuss Vaillant Ecotec pro Low working gas pressure in the Plumbing Jobs | The Job-board area at PlumbersForums.net
When he did the annual service did the engineer also open up the burner and brushed through? Has he checked the exp. vessel, flue integrity, has done all the **** ? Seems like he either was lazy and rushed the service or he has not got a clue. As @Last Plumber has mentioned if that all is true you should perhaps write an email.
No, burner was not opened and brushed. exp, vessel was topped up.
**** was done with a print out.
does my gas pipe have a gas test point valve? have attached a photos.
There is no test point installed as far as I can see. How did he re pressurise the exp.vessel ? Did he drain the boiler ? I do not mean the flue gas analysis I mean **** which are certain things to examine, gas rate, integrity of the flue, supply of combustion air,safety controls, etc...
I am not sure, but this was ticked on the service check list.
P1 is the gas valve he hasn’t added his restrictions
14 plus 3.5 of vaillants are 2.5mbar 17.5 working at the gas valve
Low working pressure is not id unless it effects combustion
P1 is the Boiler running at Max and he has tested the pressure at the valve. Shaun is right with the drop on a Vaillant in that the pressure will be higher at the appliance inlet than at the valve test nipple. Your Boiler will be three this year and I can't remember when the manual was altered but if you have the one left by the installer and it says 13 mb min, then ask them to come back.
The boiler also has not been cleaned as it should be done annually. He did not open the burner and cleaned and checked the electrodes. I would also say that the gas rate seems dodgy to me meaning I don’t believe he has ever done it. However, I would call them back
It’s not required every year
Reply to Vaillant Ecotec pro Low working gas pressure in the Plumbing Jobs | The Job-board area at PlumbersForums.net
