Discuss Vaillant ecotec plus 624 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Christopher buzzard
Hi all. Got called to the above boiler with fault code F61. Checked wiring harness from gas valve and all was ok. Reset the boiler and it worked fine. Left it running for 20 mins coming switching it on and off, it worked every time. The only thing i did notice was the display was acting up. Jumping up 20 degrees, down 10 degrees and so on. Is that down to a fault on pcb?
I believe it can be the gas valve, but usually pcb (certainly true on ecotec pro). Check resistance of gas valve pins.
pcb
Reply to Vaillant ecotec plus 624 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
