Discuss Vaillant boiler, no error on display but not working properly in the Plumbing Jobs | The Job-board area at PlumbersForums.net
armyash
Subscribed
On unvented system. Not sure what model boiler. (not helpful I know)
A tenant where I do some work has been in touch, he said the boiler was not working.
I asked him to check the usual, thermostat turned up, gas on (light the hob). Can't check the pressure because it means taking the case off to see the gauge (I assume, he said he cant see a gauge anywhere) low pressure would display a fault anyway. Trvs open.
I told him to switch off at the mains and back on. He did and he said it fired up. Half an hour later i got another text to say the rads warmed up but it's now gone off again.
He has sent me pictures of the boiler and there is definitely no faults being displayed. Waiting for him to tell me if the boiler works ok if hw is turned on.
Any ideas? First thing i'm going to do is put new batteries in the thermostat.
Had a look. surprise, surprise it was all working fine.
Tenant told me they had changed some times on the programmer so maybe they had switched the heating off by mistake.
Another thing, its an ideal not a Vaillant. doh.
Boiler display shows '0' then 'c' when there is a demand. Sometimes 'c' will show on display but the burner light doesn't come on.
Wired honeywell thermostat working fine when on site.
Any intermittent faults that are common that anyone knows of?
Reply to Vaillant boiler, no error on display but not working properly in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all I have a Vaillant eco boiler at a new house I moved into last week. It’s a combo boiler and the last boiler I had was old (and much easier to use!) This one keeps turning itself off. The hot water seems to work and is always warm. The heating also works but for random amounts of time...
H
Wishing everyone on tgmhis forum a very happy Christmas!! I am working on a combi boiler which has problem with heating only. Water is heating normally. Here are the symptoms 1. Signal from thermostat is not firing the boiler. It does not make any sound when heating is on from thermostat. 2...
Hi Folks, Where is the place to order a Vaillant filling loop, please? I looked around on the net but can't seem to find it as a kit. I'm not doing the job but he wants to know what to buy and replace it himself and asked me where to get one. I said I'd have a mooch. He sent this picture. I...
Hi, I'm hoping someone here may be able to help me out with an issue I have with my baxi duotec boiler. Basically, the hot water temperature has been fluctuating quite alot, dropping in temp then raising again whilst showering. I have had an engineer out who has changed the thermistor, but I am...
Hello, my Vaillant VRT 392 Thermostat just stopped working, it's completely dead, I read another thread suggesting changing batteries, but this model does not use batteries, it's wired to a Vaillant control center VR65 with eBUS, my boiler is Vaillant ecoTEC plus 624, anyone can help identify...
