Discuss Vaillant 630 bypass question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I understand that this still should be put in place however with the use of variable speed modern pumps set to reduce their speed as the pressure increases the likely hood is the by-pass would never open.
The more you think about the modern system designs the more I see the case for hydraulic separation, the cost of using Close Coupled Tees is small compared to LLH but it may explain why Vaillant are pushing them in the M.Is.
Many thanks to all for your input to this.
There are many ideas that are slowly making their way form the Commercial side to domestic but obviously on a small scale. Headers of various types, for example, have been used in the Commercial side for many years.
It seems to be that with some boiler's (eg. large KW output Vaillant's with high resistance heat exchangers and software which requires high flow rates before the boiler has a chance to modulate down), many domestic installers are using/relying on an ABV to overcome the problem of insufficient flow in the CH system. The task of the ABV should be to operate in the conditions described above (i.e. closing down of TRVs or ZV's), but many are set to allow the minimum flow rate required whilst these boilers operate at a high output before modulating down, at the expense of bypassing under normal conditions also. This has been my experience.
The correct solution seems to be CCT's or LLH. I think Fig 6 of this article explains well how the boiler is able to maintain it's required delta T with the use of an LLH:
Best Practice: Low Loss Headers
Reply to Vaillant 630 bypass question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I recently had a new 2023 Vaillant ecoTec plus 630 (30kW) system boiler installed along with a Low Loss Header (LLH) in my house. I have 21 rads in the house and a room with UFH. The LLH was introduced as I was finding (before the LLH was fitted) that my old boiler (Vaillant heat-only boiler)...
Hi All, Looking for a bit of advice on the best way to pipe this. - 24kW Worcester regular boiler in kitchen, approx. 9 years old - unvented tank, zone vavles, pump, expansion is on first floor in airing cupboard - Currently piped as S-plan. - Hive controls. - Would like to fit 6-zone...
I am looking to replace my existing Vaillant heat-only boiler with a new Vaillant ecotec plus 630 system boiler (30kW). I have a megaflo hot-water cylinder, a central heating system (serving 21 radiators) and an orangery built last year (6m x 4m) with underfloor heating. Through running some...
Good morning, wondered if anyone can advise please on a resolution? My set up at home is that I have a 4-bed detached with 21 radiators (includes 4 towel rails), a 6m x 4m orangery/conservatory that was built last year with under-floor heating, and a Megaflo for storing hot water. The UFH...
5K
I have a Vaillant eco plus 837, year installed 2008. It works well. We have one large zone for the house with 13 rads running off it. We also have an UFH zone in the kitchen. Near the boiler I have 2 port valves which control this part of the system. The boiler has been loosing pressure...
