Discuss V&B shower mixer - restricting pressure? in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. Unclehr
    Unclehr New Member
    Just moved into a house with a villeroy & boch shower. Water flow out the showerhead and the handheld are both equally terrible. The pressure and flow at the bath downstairs is OK at about 15L per min. There is a megaflo cylinder.
    I'm thinking that the problem must be the shower mixer or the pipe into it is somehow restricted.
    Does that sound right and if so do I need a V&B expert or is it a pretty standard plumbing job to fix?
    [​IMG]
    When I say rubbish pressure, if I turn the handheld upside down the water rises only a couple of inches before falling away. I checked the hose and showerhead for blockages or restrictors.
    thanks
  2. CBW1982
    CBW1982 Plumber GSR Top Contributor!!
    Hello and welcome to UKPF, some questions if I may?
    • Do you know the shower head litres per minute?
    • Where is the shower in relation to the downstairs bath?
    • Is only the shower affected?
    • Is the pipework to shower accessible?
  3. Unclehr
    Unclehr New Member
    Thanks for the quick reply
    OK so the bath is 15L and the shower 8. There's also a hand shower downstairs that's also 15L
    The shower is on the first floor pretty much directly above the bath
    No a lot of the basins have poor flow too eg 4-7L. The only decent flow is the bath. Even the kitchen tap is only 6
    Not to my untrained eye
  4. CBW1982
    Ok so if you have poor flow/pressure to all other outlets other than the bath, I would suggest if it hasn’t been done recently - obtain a G3 registered engineer to service your Megaflo cylinder and diagnose the issue.
    • Useful Useful x 1
  5. ShaunCorbs
    whats the flow rate like out of the kitchen cold and hot tap?
  6. Unclehr
    Unclehr New Member
    Rubbish. 6L from hot and cold.
    I then unscrewed the nozzle and I get 7L from both so hardly any difference. There was a mains outlet right below the sink so I stuck a hose on that and get 15L, same as the outside tap.
    Oh the kitchen also has a V&B tap.
  7. YorkshireDave
    YorkshireDave Plumber Top Contributor!!
    Def sounds like a servicing issue. G3 person needed. All unvented cylinders require an annual service for safety reasons.
    • Agree Agree x 1
    • Useful Useful x 1
  8. Harvest Fields
    Agree with above. Get a G3 registered engineer out. Should be an easy fix.
    • Like Like x 1
Loading...
Similar Threads - shower mixer restricting Forum Date
Mixer shower pipe sizes Plumbing Forum Monday at 1:41 PM
Traditional Mixer Shower Problem Bathrooms, Showers and Wetrooms Jun 26, 2019
