Discuss TRV missing head and odd size in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can anyone advise on the brand of TRV head that I would need for this value. Moved into a house with two radiators missing TRV heads, and they seem to be a different size/shape to all other TRVs that I have.
From the images can anyone recommend suggested TRV head that may fit.
David
Reply to TRV missing head and odd size in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a home with an oil boiler in a garage turned into a flat, heating both flat and main house, running c plan with two pumps, two motorised valves simple bi-metal thermostat on wall in flat with 4 standard TRV's rarely used so not worried about the flat, and main house has Nest Gen 3 in the...
Would like some help please as my Drayton Wiser system is a mess. I had 2 TRVs in the lounge, one in the main bedroom, the rest of the house - 6 other radiators and 2 bathroom towel radiators are just normal valve s. We live in a 4-bed, 3 storey house, as converted loft. Common problems were...
Hi - I'm a reasonably experienced DIY plumber but just can't work out why the last new rad I've installed is cold - would really appreciate your help please. I've extended an existing 'run' of radiators - the last one on the run ( in downstairs kitchen) is cold. The first rad added is...
I am trying to workout in what order my radiators heat up in order to then balance them. I am able to figure out which radiator pipe is the flow/return on each radiator so that I can then grab the right pipe to check which heats up first. There has been an extension done on this house at some...
I have a Nest thermostat in my hallway which gets affected by the front door opening and closing. This thermo operates one zone (downstairs). I have one radiator the other side of the door to thermo. I have another in the study and two more in the lounge. None of the radiators have a TRV and...
