Discuss Triton Showers Head spray plate is stuck and won't open for cleaning! in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. macrefurbs
    macrefurbs New Member
    Re: Triton Zante III 9.5kW Electric Shower (product code: ARZAN309WC)
    Cleaning The Shower Head:
    On this model, to remove the spray plate for cleaning, you have to press a button on the side of the head, and then rotate the plate past the button.
    But no amount of pressing this button, will enable the plate to rotate past the button!
    It was remove once before with great difficulty.
  2. CBW1982
    CBW1982 Plumber GSR Top Contributor!!
    Try applying some lubricant to around where the button is, it could just be limescale or something. Failing that heat it up in some hot - warm water.
  3. rpm
    rpm Trusted Plumber Top Contributor!!
    Remove shower head, stand it in a jug and pour Kil-Roc inside then add water and let soak.
    • Like Like x 1
  4. king of pipes
    Stick the shower head in a pyrex jug of white vinegar overnight less harsh on the plastic . Kop
    • Useful Useful x 1
Loading...
Similar Threads - Triton Showers Head Forum Date
Changing the thermostatic cartridge on the Triton Dart Eco Plumbing Forum Jun 18, 2019
10.5kw triton shower getting too hot Bathrooms, Showers and Wetrooms Apr 26, 2019
