Discuss Trianco Eurostar combi boiler going off in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Morning all,
Can anyone shed some light on said boiler? It’s going off on unexpectedly. This is only the second time it’s done so in 3 weeks, boiler doesn’t go in to lockout. The first time was just after having heating oil tank topped up, but far as I can see oil is flowing freely to pump. The way I restarted the boiler was just switching off and on at the mains. Could something be overheating? The water pump still seems to be spinning after boiler goes off. It’s back on working fine now, but want to pin point the fault before it happens again. Thanks for any help
If it’s not the normal ‘cycling’ to maintain store temperature (as I’m sure you’re familiar with).
The only thing it can be is either of the high limit stats tripping. Then again you have not mentioned
resetting them (one usually under the control panel)
Not sure where the other is, but they both require manual resetting??
I believe on this particular boiler both high limit and store stat are underneath panel. However he has not mentioned manual reset at all, nor does it sound like a burner lockout, hence why I asked please elaborate more. Is this happening when there is a demand for heating or hot water
Thanks for reply’s. Both times have been during the night, get up and cold house no heating on, but I can here water pump whining away still until turning thermostat down. I’ve not reset anything, no red light on control box. I tried turning it off on the time switch programmer(the one on boiler packed up so have new time programmer installed near by on wall) and then back on continuous running but nothing boiler still didn’t fire up, so turned it of just at the mains switch on wall and is running again, still running fine now. Could the water pump be sticking?
If the pump had ‘stuck’ or stopped working, for any reason. The temperature would build up and trip the high limit stat.
Could be the diverted valve not opening fully?
Unfortunately, unless the problem is obvious it is difficult to diagnose blind.
No I disagree Tea-Break. If this was a burner issue I would expect lockout. I’m looking at the wiring diagram now and it says when a roomstat is added to remove link A between terminals T and H, this link by passes any roomstat, switches valve to CH, brings pump on and allows boiler to cycle. If this link is not removed and wired correctly then there’s no thermostatic Control. Something isn’t wired right.
Sorry Tea-Break I thought he said a new room stat was wired in, not a programmer . Below is the wiring diagram as it should be, anyone who knows how to read these things will be able to trace wires and work out what feeds we have where like SimonG said. Looking at the wiring diagram it is possible the pump and boiler would get a feed and the motorised valve may not open.
I totally agree. Personally I would be checking correct wiring to start, after that I would consider faulty valve or stats failing to bring boiler on. Sorry to misunderstand you earlier, it’s Super Bowl Sunday and I’m pi**ed right up
Thanks, it Has had a new diverter valve fitted last year as old one was leaking. I haven’t had time too look any further but it’s still running fine now so will see how it goes. The thermostat is a Honeywell dial type, lookin at it looks as it’s been installed for sometime, but it still clicks in and out when boiler stopped working. Was actually looking at getting new thermostat with prog built in if any one could recommend one?
If the roomstat is clicking in and out that usually means it’s ok. If you’re not confident yourself to investigate the wiring any further then please get a good engineer in. Following the wiring diagram is easy if you have an understanding already. You could have a dodgy room stat, you could have a dodgy CH stat not bringing boiler feed on, you could have a loose wire in wiring centre not supplying power to pump and valve, the relay could be at fault, as could the valve already mentioned. The problem is this is an intermittent fault and Sod’s law is might not play up while investigating.
Reply to Trianco Eurostar combi boiler going off in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I'm looking for some advice on a frustrating problem I'm having with my old Eurostar 50-60s oil boiler please? Although it's old, most parts needed to operate it are now new. The symptoms indicated a broken/seized burner motor or oil pump. I wrongly assumed the motor so I ordered a new one only...
R
Hi, The outlet of all my radiators are at 55°C, but the boiler keep showing the Return Temperature is 60°C (and keep raising at 1°C/min rate) Also the flow temperature keeps going up above the set point and when it reaches +5°C above the set point, the boiler shuts down (even before the room...
Renato
R
I have a customers trianco burner that starts from cold ok for a few minutes (say 3minutes) then locks out then will not stay on. Boiler had not been serviced in a long time and oil filters were bunged up as was the nozzle. I decided to service it with hopes it was simple starving of fuel from...
My Grant combi oil boiler is giving me quite a headache at the moment. When I returned home last Friday I'd no heating or hot water. An engineer called the next day and diagnosed a faulty pressure switch. This was changed and everything seemed ok. However then the boiler began to lose pressure...
Hi I am somewhat confused. My daughter has a combi boiler bought 2-3 years ago and has it timed to come on in morning for an hour and at night for a few hours using "auto"? mode I had been brought up to leave boilers on manual and set the thermostat low at night to prevent pipes from...
