Discuss Tanking Hardiebaker With Aquaseal Kit. in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. Simmo
    Simmo New Member
    I'm about to complete the installation of the Hardiebacker boards in my shower cubicle. Next bit is to seal and tape all joints with Thinset and the Hardiebacker tape which I already have. I intend to use a tanking kit to ensure that all is well before tiling.
    Question is ..
    I see that there is adhesive backed sealing tape in the tanking kit (Aquaseal kit in my case) Do I still need to use the coarse Hardibacker tape and Thinset on the cement board joints and then use the Aquaseal tape over the top? My concern is that I don't know whether or not the Aquaseal tape will stick well enough to seal if it has the Hardiebacker tape and Thinset underneath it. Or .. Do I just seal the joints in the board using thinset and then smooth off excess and, after priming, apply the adhesive backed Aquaseal tape straight on top without the Hardiebacker tape?
    Thanks very much.
    Dave.
  2. oz-plumber
    oz-plumber Plumber
    What do the instructions say?
    Follow them and you might not have a problem.
    Other than that get an accredited waterproofing specialist in.
    Shower leaks are a painfully expensive problem to fix.
    They generally need a full replacement.
  3. Simmo
    Simmo New Member
    I've pinged a quick email off to the Aquaseal guys asking if the tape in the tanking kit can be used instead of the mesh Hardiebacker tape. I guess that if the tanking kit provides a fully sealed surface, then the thinset and tape on the cement board joints wouldn't be required?
