Discuss System boiler replacement...... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi....looking to replace our system boiler (ch/hw tank set up)
Was considering the ideal vogue but open to other suggestions. Have had a worcester bosch before but that was a combi
Assume benefits/downsides to all brands but looking to limit the downsides
Ta
viessmann 200 4 pipe
worcester cdi con is another good one
Vogue are good. They have had one or two issues. Vaillant have been consistently excellent. I think a lot of guys on here would agree that it’s as much about your installer as it is the boiler
Reply to System boiler replacement...... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Home owner looking for some advice pls. We have a megaflow system which we are considering removing as the tank takes up a lot of space and we don’t find we are using more than one shower or bath at a time. Our plan is to do this when the current boiler needs replacing (probably in the next...
Hi, I am replacing our 11 year old boiler (due to H.Ex. leak) with a new one. This is in a "sealed" system with red expansion vessel in airig cupboard & a megaflo (no tank in loft). However the exisiting boiler is Vaillant ecoTEC 4xx boiler - which is satated by vaillant as an "open vent" boiler...
Central Heating Pump - G Pump Force HE-RS25/6PWM-130 Hi, I would be grateful if someone could explain whether our CH system can cope with the AUTO (adaptive mode) setting on this the new pump or which mode it is best set at (recently had our old 3-speed pump replaced with the above smart...
Hi I seek some advice on replacing an existing regular boiler. I currently have an old Potterton 10-16 Netaheat electronic, which is around 35 years old and still working OK. It is fitted to a std 'Y' plan system with boiler in utility room and separate hot water tank, pump, valve etc in...
I've got a non condensing Glowworm Ultimate with gravity tank and hot Water tank in a 4 bed house. 11 radiators 1 double 1400mm length 1 P+ 1400mm length 2 P+ 400mm length 7 singles 400mm 1 mains shower average water pressure Any recommendations on combi boiler and KW? Boiler budget...
