Discuss Smelly shower trap in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. Bettyboo
    Bettyboo Member
    Hi All
    My shower tray and plumbing was installed 5 years ago and has been fine up until last summer when it started to smell. We have been careful to clean trap parts weekly to remove hair etc but last summer when it was not being used quite so much it started to give off a stale kinda dirty water smell.
    I had a go at getting rid of the odour with half a cup of vinegar and half a cup of bicarb of soda mixture but the mixture sat in the shower well with some of it draining through the pipe drain. I am not sure whether this method was appropriate to get to where the problem is. Please see pics
    Anyway it still smells, any answers please?
    Thanks alot
    Betty
  2. bogrodder
    bogrodder Plumber GSR
    I think you’ve got part of the trap missing
  3. bogrodder
    It’s sits on the little lugs attached to the outer ring and creates the trap. At the moment, horrible gasses can enter the bathroom
    • Agree Agree x 1
  4. scott_d
    scott_d Plumber GSR Top Contributor!!
    Agreed
    With out the cover you don’t have a trap
  5. Bettyboo
    Bettyboo Member
    Sorry please see other parts to trap . Second one shows water level.
    I just usually insert parts thinking nothing of it, first basket then central bit and then chrome cap. Not sure if there is special requirement on how tightly they must be fitted/connected and the water level etc
    Betty
    Central bit
    Basket
    central bit inserted in basket
  6. Ted808
    Ted808 Plumber GSR
    Check the water level in the trap after using something nearby , it might be that another drain could be 'sucking' the trap dry and then the smell can escape.
    • Agree Agree x 2
  7. WC1
    WC1 Active Member
    Normally that'll be a wc flush nearby.
  8. CBW1982
    CBW1982 GSR Top Contributor!!
    It could also be getting siphoned out if anything material wise caught, but unlikely given the pics. You may also have a build up of soap scum in the waste pipe, does it drain slow?
  9. Craig Watson
    Craig Watson Plumber GSR Top Contributor!!
    Can't remember off the top of my head but is there a rubber o-ring on this part?
  10. Bettyboo
    Bettyboo Member
    We have been making sure the trap stays topped up with water and the smell has gone. Hooray! or for a while anyway.I think Ted and WC1 were right, welldone.
    It drains ok and there is no rubber o ring
    Thanks very much for solving a smelly problem xx
    • Like Like x 1
Loading...
Similar Threads - Smelly shower trap Forum Date
Smelly hot water . Why? Plumbing Forum May 24, 2019
Black, smelly copper pipes in new build (Gloucester) Plumbing Forum May 6, 2019
  1. smelly shower trap
