Discuss Single Pipe Valve / TRV Help in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a single pipe system (Yes I know most people will say upgrade to 2 pipe). I have installed Honeywell TRV and have some issues (Rads not getting hot) which I believe are due to the TRV (reduced flow), have tried bleeding rads, balancing etc. If I take the TRV head off they heat, put it on they don't.
It seems Danfoss are probably the only single pipe TRV manufacturers. I'm looking at the 2 options but they are silly expensive.
Danfoss RA-G15 angled valve 1/2 | Wolseley
Danfoss radiator fixed sensor 5-26c | Wolseley
If I used a manual valve would that be compatible, I appreciate they wont be 'thermostatic' but at leas I can turn them up and down as needed to get heat to the Rads.
Myson Fullflow angled valve wheel head 15mm x 1/2 Chrome Plated | Wolseley
Or are there issues with certain flow through manual valves? Another other suggestions?
I had a 1 pipe system in a previous house, never had any issues with it. A lot of guys would replace because it’s not what they’re used to. You haven’t got a pump forcing water through the rad so you can find sludge builds up if you don’t use inhibitor etc.
It’s a new combi boiler and new rads and has has inhibitor. Didn’t realise it was one pipe until the engineer came to install the boiler, it always worked fine before hence I think the issue is the trv.
Reply to Single Pipe Valve / TRV Help in the Plumbing Jobs | The Job-board area at PlumbersForums.net
