Discuss Shower waste via old toilet stack in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I’ve found an old toilet stack to a drain in a downstairs bathroom which was capped off. It’s still open and connects to my sewer line on my property. There is a man hole cover just outside and it drains.
I want to drain my shower waste through it.
If I make get a U bend and drain the waste into this pipe is this:
1 Allowed?
2 is there a way of connecting a smaller pipe to the old underground waste pipe 110 mm. I have about 15 cm clearance with floor?
Advice gratefully received.
Reply to Shower waste via old toilet stack in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all I really need some help or advise….. Back story….. Some years ago my dad had an extension to his house which included a newly built downstairs shower room. Recently he had this downstairs shower room re-fitted/decorated. Quite a simple set up consisting of a sink, toilet and shower...
Hi all, grateful for your expertise on the following. DIYer, not pro. Rural property in France Single storey. Septic tank. Late 80s construction with concrete slab subfloor. All of the waste pipes run in the concrete, and exit the property at the chamber as pictured, just outside the building...
Hello hello,, Hoping there are some experts or experienced Bulgarian plumbing chaps in this site ?. Here in the UK I can fit a bathroom just with the experience I have picked up over a lifetime. I can make copper pipe runs isolaters taps sink shower etc but me and the missus have bought a small...
As part of a slow DIY bathroom refit I've removed the old toilet from the original location next to the soil pipe (and obviously capped off the branch) and plan to place it the opposite end of the room. I was pretty lucky to find a 110mm sewer waste pipe below the old sink which is the new...
Hi I'm currently doing the pre-planning for my next DIY project fitting a shower tray and enclosure from scratch. I'm confident of being able to do the job but not being a plumber not sure the best way to go about it so would appreciate any advice. The current upstairs room has a black waste...
