Discuss Shower tray draining slowly in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. Chris B
    Chris B New Member
    I have a wet room type shower, the waste is slow at draining, so I have removed the cover and want to use one of those unblock wires to see if there is any sludge in there.
    Most of the hole is taken up by a plastic pipe (possibly an airlock). I cant seem to feed the wire very far. Could somebody point me in the direction of what this is, is there a way of increasing the flow?
    I've attached a picture.
    Thank you
  2. townfanjon
    Not sure what you mean wet room type shower , thats a standard shower trap .
    Can you get to the other end of the pipe , i.e where it joins soil pipe ?
  3. Chris B
    Chris B New Member
    Sorry, wet room not relevant.
    The floor is all tiled so there is no access to the soil pipe join.
  4. king of pipes
    You need a ro pump bud maybe able to hire one for less than £50 or bite the bullet a get your own . Kop
  5. JCplumb
    JCplumb Plumber
    There's no nack to it, you won't get your drain spring down there, some types of traps yes, but not that one. To rod it or clear it mechanically you'll need to gain access, either underneath or outside or wherever.
    It amazes me when I get to a wetroom or low profile shower tray and the installers didn't leave access for this. Bet they give a tail-light guarantee, i.e. the job's guaranteed until you see the vans tail lights...
    You could try chemicals, my personal fave are soda crystals, a quid a bag at the supermarket, follow the instructions and make a solution, clears most stuff from drains and is 'relatively' safe.
  6. townfanjon
    As the” Kopsta” suggests the ropump or a plunger maybe your only wayout . Dont go mad plunging if you blow a pipe off , you are in the ****.
    • Agree Agree x 1
  7. JCplumb
    JCplumb Plumber
    He'd need to check the waste fittings are solvent first, seen one of them pop a pushfit waste fitting under a shower tray.
  8. king of pipes
    Agreed don't go crazy with it . kop
  9. Chris B
    Chris B New Member
    Thank you all for your helpful suggestions - will start with the crystals, then try a ro pump (with moderate force!)
    • Winner Winner x 1
  10. Ben-gee
    Ben-gee Plumber Top Contributor!!
    As above, go gingerly with chemicals and pump...
    Looks like a wirquin twisto or mira vortex trap; I now bin these and use normal dip tube wastes as those two seem impossible to clear. Luckily they are "self-cleaning" so silly me what am I worrying about?!
Loading...
Similar Threads - Shower tray draining Forum Date
Shower Alcove upgrade - Tray or Wetroom look. Bathrooms, Showers and Wetrooms Saturday at 10:13 PM
Shower Tray choice of these two??? Bathrooms, Showers and Wetrooms Jun 12, 2019
