Discuss shower riser not high enough for me in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. chenks
    chenks Member
    OK, so i've to an electric shower fitted over the bath. just a usual wall mounted one (see photo of installation)
    [​IMG]
    problem is the riser is fitted in a way that even when it's pushed to the highest possible position it's too low for my height. i don't really want to have to un-do the riser and move it physically up, as that'll leave holes in the existing tiling (i assume, as it was fitted already when i came here).
    are they are extensions or similar that can be fitted to the existing riser to make the shower reach higher?
    i'd like to be able to stand under the shower without having to stoop :) (i'm 6' and it currently sit at about the same height).
  2. dancinplumba
    dancinplumba Trusted Plumber GSR
    lift it up and fill holes with silicone or grout
    • Dislike Dislike x 1
  3. chenks
    chenks Member
    I've already said that's not the preferred solution (I did specifically say that in the opening post)
    • Funny Funny x 1
  4. dancinplumba
    yes i know but why is it such a big deal to do ?
  5. dancinplumba
    fit another rail further up ?
  6. chenks
    chenks Member
    Are you able to answer the question I asked?
    • Winner Winner x 1
  7. dancinplumba
    i will have a look on google for you
    • Funny Funny x 3
    • Disagree Disagree x 1
  8. dancinplumba
    • Informative Informative x 1
  9. chenks
    chenks Member
    Don't bother!!!!
  10. dancinplumba
    bet you've had a sneaky peek and thought yeah that's just what i want
    • Funny Funny x 2
  11. chenks
    chenks Member
    Do you always come across as a dick? Or is it just a bad night for you?
    • Funny Funny x 1
  12. dancinplumba
    only two options ? Hmmmm
    • Funny Funny x 1
  13. dancinplumba
    well I did give you three
  14. Phil
    Phil Plumber
    What the hell is going on here? Have you too met before?
    • Funny Funny x 2
  15. Phil
    Phil Plumber
    Looking at the picture, the Dwarf who fitted it has kindly drilled on a grout line and if he's used red plugs just maybe there is not too much tile drilled out so a bit of blending with sandpaper and new white grout and a longer riser might just work.
Loading...
Similar Threads - shower riser high Forum Date
Shower tray riser panels Bathrooms, Showers and Wetrooms Mar 13, 2019
Shower Niche Bathrooms, Showers and Wetrooms Today at 11:47 AM
  1. what if shower riser kit is not high enough
