Discuss Sewage Gas leaking into house in the Plumbing Jobs | The Job-board area at PlumbersForums.net
So, we moved into a new build a couple of years ago, and a few times now, we have been woken to the smell of sewer gas in our house.
The problem seems to be a rubber bung in the kitchen floor under the kickboard, it connects the sink to a 4" sewage pipe, and it pops out periodically. It also seems to coincide with Northumbian water vans knocking about. One time raw sewage was spewing down the street.
It happened last night again at 1am, and not long after there was a team of lads pumping out the drains in the neighbouring street. I went and had a word, they said there was a blockage at a pumping station, and to ring them today.
Is this an issue with the rubber bung, does it need to be refitted replaced, or is it an issue with the sewers that is causing pressurised gas to push out the bung.
My house doesn't seem to be vented, there is a pipe in the loft that goes no where.
Thanks,
Jon
Rubber bung type reducers should not be installed internally, for this very reason, they are for external use only.
It needs to be replaced with a solvent weld type & the vent in the loft needs to be investigated as it should go to atmosphere. It is not allowing the back pressure to dissipated so it will cause these problems when there are issues further down the system.
Thanks,
Jon
Ok Mr Wilson, I think your post
is very serious on many levels.
You say sewer gas...or is it carbon monoxide, or methane ?
how do you know. Do not rely
on your housebuilder...call your utility directly and get the gas checked NOW. Then call the water utility and do the same, methane is just as bad. Then get a professional outfit to call by for an hour..pay them to get their report...then u will feel
safe OR not. If this was my gaff and my family I would not sleep,there and I have 45 years
experience in this industry
Well Rob he knows it isn't carbon monoxide for sure cos it doesn't have a smell.!!:oops:
& secondly if the bung is out after being push back in I would say it is pretty conclusive.
Maybe stick to the "centralheatking" mate.
Photograph(s), please.
Images of bung attached.
The whole bung raises up a few centimetres. When you get down to take a look the smell makes you want to hurl.
Jon
You Wuss Jon, now you know what us plumbers have to put up with.:p:p:confused::eek:
When you said new build I assumed the underground would be brown plastic but it looks like clay pipe might have been used. Do you know what the bung is pushed into ?
Top UP Mate is going well on its own now thanks 2640 sold in last 3 months. Rob Foster
aka centralheatking
Sorry I can see the edge of clay pipe in the other photo. You will need to fill the hole up with some lean mix sand & cement to hold it in place as it is going to be hard to get a correct joint to replace the reducer (bung).
The problem is that your drain system is not vented to relieve the back pressure you should have this corrected.
Sounds a bit suspicious. If there's enough back pressure to push out a bung it will be more than enough to push past water traps in WCs and sinks and send the pong into your kitchen/bathroom. Personally, I'd have a vented stack on my property at the top of the line and only rely on AAVs for stub stacks further down.
This a good demonstration why taking the easy route with the vent being terminated with only air admittance valves can be a bad idea. Seeing this more and more now.
so correct, especially as with all things they wear out. Seen air admit s in some very funny inaccessible places, it is a cheap answer to the problem with long term implications in my opinion
Reply to Sewage Gas leaking into house in the Plumbing Jobs | The Job-board area at PlumbersForums.net
