Discuss Salus IT-500 wiring help in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi pretty new to this forum so bare with me.
I've fitted these before but only on combi boilers and now I need to fit one on a separate hot water and heating system.
It's the salus it-500 and I have attached my wiring scheme. Just need to know which one goes where on the salus it500 if you are familiar with the set up of them.
Peter
y plan system?
this should do it
Thanks so do you mean scheme C ?
Can you say from my wiring which wire goes to which... Eg. 1 goes in to C etc
Obviously I get where L and N go. But you have NO and COM and just need to know which wire number on my current setup goes where?
yes done the wire colours if you see my pic
Shaun, all of your pics state for Combi boilers, yet OP states it’s not for Combi boilers and for conventional system. My understanding is if it’s the same wiring setup then it should clip onto industry standard backplate?
C diagram on my pic if you look I’ve put the correct colours in the correct terminals for you see the red yellow and blue lines
Can’t no one see them ???
Yes I can see them, didn’t know you had put them in :oops: it just the wording above states for Combi boiler, didn’t know it was the same for standard systems as well - always learning :D
Yea I see it now I think I wasn't looking properly
Ok thanks for this I'll give it a whirl
Is it ok to out the two live and two neutral in to the same one also as it is on my original images?
I note image c is for 2 zone central heating systems so does that account for the separate hot water in the upstairs tanks etc
They should fit
:D all it does is replaces your prog so aslong as your system is working now should work once finished
Er no ... it replaces the controller and the room stat
True If he has one but that can be addressed or left fully on / max or linked out
Upto you if your happy leaving it on max (the room stat) then my drawing is fine
If not two options link out on the stat eg joining the live and switch
Or up in the wiring centre removing the stat and bridging / re connecting
Two options
Move yellow wire into the red terminal
Or
Wiring centre
Find the room thermostat wires remove them and install a link where they used to go
Sounds easier to put yellow to red
Can you snip the image and just show me with a coloured line (like you did originally) which yellow goes to red etc
On the stat just move one tbh if your unsure of that best to get a pro in
I’m too busy but you can ask D R plumbing and heating if he’s got time
Reply to Salus IT-500 wiring help in the Plumbing Jobs | The Job-board area at PlumbersForums.net
