Discuss Replacing Shower Mixer with inlet nuts concealed behind cups in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. Daniel Isherwood
    Daniel Isherwood New Member
    Hello.
    I'm intending on replacing my 20 year old Hansgrohe Shower Mixer.
    As seen in the photos, the inlet nuts are concealed beneath the cups that screw onto the pipes. Most modern mixers have the nuts visible and in between the mixer bar and the cups.
    Will I be able to replace the mixer with a modern type?
    Any thoughts welcome.
  2. Harvest Fields
    Email hansgrohe the pics and see what they come back with mate.
    • Agree Agree x 1
  3. Daniel Isherwood
    Cheers - I'll have a go.
  4. CBW1982
    CBW1982 Member
    What’s behind the silicone? If it’s copper then you should be able to get a replacement. As @Harvest Fields@Harvest Fields said maybe send photo to hansgrohe or any other manufacturer that you intend on replacing with.
  5. JCplumb
    JCplumb Plumber
    Make sure the centres of the feed pipes are 150mm if you're not going with a like for like replacement, they look to be less to me.
    150mm is the most common width needed for exposed showers.
    • Like Like x 1
  6. CBW1982
    CBW1982 Member
    Some do come with an option to suit different centres. ;)
Loading...
Similar Threads - Replacing Shower Mixer Forum Date
Replacing Mixer Shower help Bathrooms, Showers and Wetrooms Jan 8, 2019
Replacing concealed shower... Bathrooms, Showers and Wetrooms Dec 6, 2018
