Discuss Replacement part for bi-fold shower door in the Plumbing Forum area at UKPlumbersForums.co.uk.
  1. Christopher buzzard
    Christopher buzzard GSR
    Morning every1. Need help with either a website or what you would call the part I need to replace on this shower door. Not even sure if yo can buy parts for it. Age unknown. 760mm door.
    Many thanks.
  2. Harvest Fields
    Morning. Sure I have been asked about this brand before. Do not think they are around anymore. Might be time for a new enclosure.
  3. Christopher buzzard
    That’s what I was dreading. Replacement wouldn’t be easy as for what ever reason they fitted the screen 1st then tiled up to it, both sides. Hence they have siliconed both sides Ect. Would never put a new screen back like that so worse case it would have to be re-tiled or panel boards before fitting new screen.
    • Like Like x 1
  4. Harvest Fields
    As I say mate. You can never under estimate the power of stupidity. I am seeing more and more like this when they are in elcoves. The last few I did I managed to get very similar replacement tiles. Maybe you will be as lucky.
  5. rpm
    rpm Trusted Plumber
    Try fleabay, all sorts of runners, wheels and other there
    • Agree Agree x 1
  6. YorkshireDave
    YorkshireDave Plumber
    Ok, bit out of left field, but what about 3D printing? Or failing that, have it machined from aluminium. Whilst it won't be dead cheap, it'll last!
  7. Harvest Fields
    Probably cheaper to rip out. Fit new screen and match tiles.
Loading...
Similar Threads - Replacement part fold Forum Date
Baxi Neta Tec Problem + Pos Replacement Central Heating Forum May 18, 2019
Ball cock rubber washer replacement. Plumbing Forum May 4, 2019
