Discuss Removing A Dishwasher in the Fittings & Pipes area at UKPlumbersForums.co.uk.
  1. Defaulty
    Defaulty New Member
    I want to remove a broken dishwasher, but removing the waste pipe needs a waste pipe cap, and I've looked everywhere for the right size.
    50mm is too big and 40mm is too small, and there is no size in between, I did buy a 43mm but that turned out to be the same size as the 40mm.
    This is the thing I bought:
    40mm Solvent Weld Access Plug White waste Each new | eBay
    Am I buying the wrong thing here? It's just the screw cap I need.
    Either way.. 50mm is too big and 40mm is too small.
    Should I be buying the push fit caps? But wouldn't the sizes be the same?
  2. Defaulty
    Defaulty New Member
    BTW it's to go under the sink etc.
  3. Craig Watson
    Craig Watson Plumber GSR Top Contributor!!
    What is it your trying to cap off? Can we have a picture.
  4. Defaulty
    Defaulty New Member
    I haven't got a camera to take a pic but it's like this.
  5. Defaulty
    Defaulty New Member
    So the sink pipe needs a cap similar to the ebay screw cap, to stop the water flowing out.
  6. Craig Watson
    Is it this part your trying to cap off?
  7. Defaulty
    Defaulty New Member
  8. Craig Watson
  9. Defaulty
    Defaulty New Member
    I'm confused, this will block the water when I remove the dishwasher?
    The long part is sealed off right?
  10. Craig Watson
    Yes, what you have now is the same but the end will be cut to allow the hose to go over it. The part in the link will be blanked off ready for cutting.
  11. Defaulty
    Defaulty New Member
    Oh ok, I just always presumed I had to unscrew everything and get a flat cap, but thanks, I'll look into buying one of these.
    Maybe I'll buy a 50mm and a 40mm just to make sure.
  12. Defaulty
    Defaulty New Member
    Or is that the right size for all, the 1.5 inch which is 40mm right?
  13. Defaulty
    Defaulty New Member
    Nm, I'll just buy the same one from screwfix, thanks man.
  14. SimonG
    SimonG Trusted Plumber
    Duct tape.
  15. ShaunCorbs
    Marigolds rubber glove tip
Loading...
Similar Threads - Removing Dishwasher Forum Date
Removing Flux Stains Plumbing Forum Mar 12, 2019
Tool for removing cartridge? Valves & Taps Mar 2, 2019
