Discuss Re-using existing connection to a replacement Cylinder in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I'm renewing my old indirect cylinder with a like for like replacement (albeit with an additional shower take off point). I intend replacing the cold feed and boiler connections with new pipe as they are pretty easy to replace.
My question is about reusing the existing hot water take off point at the top of the cylinder. My gut feel is telling me that using the existing pipe and olive could result in a poor seal and a leak.
I'd appreciate and tips or advice please.
Thanks.
Thanks.
Sometimes depends on the olive, if brass, then usually ok to reuse. Copper, I’d replace with a brass one.
Usually you will find tiny differences in the pipe to cylinder connections where the angle will vary or distance too short or to tight.
You won’t know exactly until you have new cylinder set in position.
Very often I am able to use existing olive. Use paste to help seal it
Sorry for the slow response.
Will let you know how I get on. Unfortunately, the only way I can get to the cylinder is to remove the bath, so a bit of planning is required. (The previous owner of the house - a heating engineer - extended the bathroom and it now includes what was the airing cupboard. Unfortunately, the bath is fitted in front of the cupboard that houses the cylinder, so its a cow to get at. I am planning to carry out the work in a couple of weeks and will then re-fit out the bathroom.
As a final question. I want to be belt and braces with the connections on the boiler. As mentioned I will renew pipe where necessary and fit all new olives. I know Boss white is not a good idea as it can make future removal difficult. Any recommendations on a decent sealant to apply to the olives before tightening. Just to be sure.
Thanks.
For paste I now use V2 Lube.
It is expensive for just a one off job though.
Does potable water and gas and is none hardening, so joints later won’t seize after using it. Good shelf life too
Thanks Guys.
I should have said cylinder in my above post. Not boiler. Given how tricky it is to get to, I'll use the best sealant available.
Many moons ago I worked for a precision engineering company on medical anaesthetic tables and all the pipework used compression fittings and we never used anything on our olives. But they were copper olives which I preferred. These days I've had the odd problem with brass olives.
Thanks Guys.
Brass olives are actually better than copper if good quality and onto copper pipe.
Copper olives tend to be very soft, which might seem ideal, but can flatten in too much and also allow movement on hot pipes causing slight weeps eventually.
Yes, I guess there is something in that. Although some of the problem with copper can be caused by over tightening. These were cold gases with no heat involved.
Cheap fittings these days arnt built to spec if you used all branded fittings eg conex Yorkshire etc you wouldn’t need any paste
Yes, there's an awful lot of cheap crap around. In this instance, I am connecting directly to the cylinder which has 22mm and 28mm compression fittings. The cylinder was made by Newark cylinders in the UK to the dimensions I gave them to match my old cylinder with the addition of a 22mm shower take off point (its a bullet cylinder 350 dia x 1500 high). So in this instance I'm hopeful all will be to spec.
In my original question I was concerned about using existing pipe/olive for the hot water take off. But I'm going to replace the olive and provided the pipe is undamaged will then re-use. All other pipe work will be replaced. Given the awkward position of the cylinder and its associated pipework, I'm trying to be belt and braces. Hence the question of paste, although in an ideal world I know I shouldn't need it (not wishing to open a can of worms here)
When you get a weep at a compression joint and you give it another nip up, and another, .... and then the drip appears again, you will wish you had used paste. :)
Can also be a lot to do with condition or type of pipe.
As I often say, - when you see some slight corrosion on a brass nut or find it seized, then it has been leaking slightly.
Reply to Re-using existing connection to a replacement Cylinder in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi - I'm not an expert but wondered if anyone might be able to assist. I've replaced an old toilet with a new one. I've used the same water inlet pipe, and have just replaced the right angled soil pipe connecter (110 at toilet end to a 97-107 connector end to existing soil pipe). It's secured...
1K
Hello, my Mothers heating failed in the recent UK cold snap. I found the pump was stuck. I have a question about pump orientation. The existing pump flows downwards. The manual for the proposed replacement recommends that it should pump upwards. This would involve rearranging the flow &...
Hi I am trying to replace my bathroom tap with a new one, I am trying to remove the existing rusty flexible tap connectors from this bit of 22mm copper pipe. But this thing is not budging at all its like its welded or super glued on, I am using some water pliers on both points here but its not...
Good evening, I'd like your opinion on something that is worrying me please: my landlady's plumber replaced the bottom/night element of my 20-year-old unvented cylinder (an Ariston Classico HE STD 150) 5 days ago and I hadn't noticed that it was leaking. He fixed the leak today but now the...
Hello, I am renovating a small bathroom in an apartment on the 5th floor. Heating is electric, no gas or oil. I have four (related) questions about this below. I had intended to reuse the cold water tank and the cylinder sitting underneath it but my plumber suggested I replace the cylinder as...
