Discuss Rayburn 480k mostly not firing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Having troubles with the Rayburn 480k and possibly supporting plumbing.
When the Rayburn is cold it will fire but only one side cooker or boiler, you can not have both, and boiler is more reliable than cooker, I also think that the diverter valve or cylinder stat is not working but need hot water to pump before being able to check. The Rayburn will run for 6/7 minutes before stopping for 10 minute rest may or not fire and run again, not because of room thermostat temp.
Any advise would be welcome to get cooker and boiler working together.
mmm had phone call at work just after lunch to say that the third engineer had arrived. I arrived home to a cooked roast dinner and a tank of hot water. A sentence I thought I would never use. This guy and his son need knighthoods, we on the other hand got a new a built-in programmer, a cooker thermostat and (on order) the motor, electronical top of a diverter valve. The Rayburn also needed and was given a good clean out, something that had not happened for 3/4 years, my second year in the house. It really is like a new machine, maybe, this will save my Rayburn relationship because so far it was just a lump of scrap that looked the part.
Thanks for the update. I refuse to work on those Rayburns, so couldn’t advise.
Personally I think they are over complicated.
Sometimes one’s genuine desire to help outstrips ability or knowledge often with good intentions- but yes it’s best to say sorry pal I can’t help you this.
Reply to Rayburn 480k mostly not firing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have a Vailant EcoTec Boiler with a Megaflo. These are controlled by a Honeywell controller. I have one 3 port diverter, where one of the outputs goes to a 2 port diverter prior to the Megaflo (I believe this is some safety feature). I have run into an intermittent problem where some...
I have a fault on my Rayburn 499KB. The boiler side fires up fine when cold. Once its hot, or oven hot, it will not fire & goes to lockout. Cooker side is working fine. Has Ecoflam twin burners. I have had the burner out & replaced damaged PEC, leaking capacitor and both burner nozzles. Have...
1K
L
Hi, I'm hoping someone has some experience with this: I'm trying to arrange for my gas Rayburn to have its heating and hot water side isolated, whilst still being able to use the oven. My plumber has concerns over whether or not this is possible, I.E. he can remove the flow and return, but...
Johnno
J
Any advice welcome as plumber stumped Had 36-46 grant vortex utility boiler 7 years no problem recently oil tank move and tigerloop install (tank about 1m lower). 10 days later and boiler either doesn't fire or fires stops, fires runs splutters stops. Most it runs now is 10 mins, but that's...
 Our heating stopped working today. We've got a Veissmann boiler that's under a year old, and an older Megaflow cylinder, and two diverter valves (all about 10 years old). We also use a Hive thermostat.
 When I boost the hot water with Hive, the receiver near the boiler shows it's...
