Discuss rat ate through a soil vent pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Ted808
Any advice to repair not replace... please! It's obviously in the tightest space and in the smelliest tiny room. As in RIP ratty. It's also on the joint of a 100"-90" reducer!
Was thinking fibreglass wrap?
Whatever way you repair bear in mind rats usually head towards light sources and will eat way through thin pipe walls if they can see light thro it. Thus the thin flexi pan connectors let light thro and are prone to being gnawed through. So your repair ought to be light proof, ie thick and wrap some chicken wire into the fibreglass eg. Rob Foster
aka centralheatking
Pics?
Rat blockers can work but that horse has bolted.
Also they need to be installed carefully (usually on last i/c before main), and all rats upstream of the blocker need sending to the great sewer in the sky and all other potential access points into the upstream area need blocking (cracked pipes, dry traps etc.).
A fernco over the hole might temporarily stop the rats seeing and smelling a way out while you consider your options. (but clearly they will chew through if so minded)
Pics?
Yeah I tried to add pics but they wouldn't load... Will try again. Hopefully rat catcher will sort the rats.
Just go mad with fibreglass matting, some chicken wire. It does not need to look pretty. If thats the stink pipe going upwards carefully stuff some chicken wire in the pipe in a ball as well. Get an air pistol and have some fun. If you live near Ormskirk my mate lends his little dog out overnight he is
very effective on vermin.
centralheatking
Sorry mate, customer needs to pay you to cut that out and replace. You'll be in the stink later on personally if it floods because of a bodge...
Client wants the cheapest option of course! I made a bespoke ali plate and attached it with jubilee clips and then covered it in a setting compound! Not easy , let alone the stink of dead rat still in my nostrils today- smelt like the stinkest cr*p ever!! arghh, i gagged several times. Plus, i was in such a twisted position that I've probably done an injury- blood sweat and gristle, for a few bucks- WHY?
I'll try a few more photo's when I get a chance...
Why do they always want the cheapest option? Gets on my nerves, rather than a correct repair/job. I work hard for my money and don’t like to part with it, but I’d rather have a job done correctly rather than more than once :eek: rant over :)
Good idea , I'll document in invoice WC1.
Here's more pic's- as you can see access was tricky and the smell of the dead rat worse- I was going to cut above into the T and join with a rubber coupling, and about on the 3" and do the same, but I was afraid that if I coudn't get enough purchase, I'd be scuppered as there is no way to get to the base of the T- without major un-plumbing and re-plumbing the UVHWC! It was the best solution to cover and seal- I think, or walk away....1.jpg 2.jpg 3.jpg 4.jpg
mac drain connector into the top of the tee then a fernco 4" to 3" adapter on the end of x amount of pipe
but good effort
but good effort
Would the drain connector be stable? as there would still a bit of pipe inside the T. Also the problem was I couldn't get to the pipe to cut it, it was tight against the wall and all the pipes from the UVHWS plus all in the way... it was a struggle- I had brought two rubber couplings and a bit of pipe, with a reducer, but seriously the smell- I had to do it as quick as possible, or vom. BUT THANKS!
Yes think of a pan connector but for 110mm soil pipe
Won't it be silly like 110 less the internal pipe bit - down to 950 too tight for the Mac ribbed spigot? Just I've had situations before= not on soil stack but other waste where it's just not quite right / matching sizes.. very annoying - you know what I mean?
Designed to fit inside pipe
Ted, you did ok with what you had and in difficult circumstances. It could always have been done different. Don't listen to the armchair plumbers
:D:D
From my experience ( Oxfordshire ) what you have there is very unusual.
I would be against undertaking a repair that does not involve replacing the damaged area on a like for like replacement. Rats don’t just eat through pipe - there is something attracting them - light is the obvious cause. It may be that the original pipe was cracked - but if your photo is showing the full extent of the gnawed hole - that is a serious rat problem.
Fibreglass wont give you a light free repair, once rats sense light they will gnaw their way through it again - and you will be (possibly) be blamed!
Sorry, but I have been there on a “best endeavours” approach - then the customers insurance company attacked me. Not for the repair I undertook, but for the consequential damage that the “second invasion” of Mr and Mrs Ratty caused - eating the telephone cables!
I guess they were calling home!
It is also possible the rat smelt the outside through a tiny gap in the solvent weld joint. light will attract them but smell will also.
Reply to rat ate through a soil vent pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I've not posted for a while, not a plumber, but a keen DIYer who likes to try and do things without bodging if I can. Basically I'm wanting to create a cloakroom toilet in our utility room, theres already hot and cold feed so thats one job made slightly easier, thankfully. The problem I'm...
small hole in plastic waste pipe which is the better fix ? Hi there need some advice please, i have drilled a small hole in the plastic waste pipe which serves the sink & shower in the loft when doing some work in the toilet underneath on the ceiling i have cut away the plasterboard to reveal...
Planning drainage for a new bathroom. Assuming that all the falls/gradients are correct is there anything wrong with this plan? Soil pipe from toilet goes through wall below the floor level so that I can connect a shower waste (wetroom so flush with floor). On the other side of the exterior wall...
1K
Hi, Short version: I have about 4" of pipe sticking out of a concrete floor in a cupboard. It makes a 45-degree bend as it exists (bent, not with elbows), the last cm before the open end is pretty much straight, but as a result of the bend it is not perfectly round. I mean it is pretty much...
TL/DR: Can I have a bend of 90 degrees in the dry section of a 4-inch soil vent? Hi. I am renovating a small bathroom. There is an awkward part of the wall where the builders boxed off a large section just to conceal the 4-inch soil vent. I realise, of course, that the soil vent is essential to...
2K
