Discuss Radiator TRV 15mm but radiators 22mm?? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hello, not a problem I’ve thought about before, but having an achp fitted so I need the maximum flow and return volume. However I find I can’t get 22mm TRV/ emitter valves only the standard 15mm. This seems bizarre due to the standard emitter Inlet/ outlet bore size. Will this cause much of a restriction to the low temp system?
Thanks. It’s mainly for the increase in pipe sizing due to the air source heat pumps lower temperatures. I’d be interested to know where you can get them as google doesn’t want to know? Cheers
What flow rate are the rads you will be less than 15mm I think so the issue will be the rads not the trv
Reply to Radiator TRV 15mm but radiators 22mm?? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I need some advice. I am trying to replace the manual radiator valves on a towelrail with a TRV: I ordered a Myson 2TRV15SN, and the tail seems to be identical with the current setup, however I am not sure who to attach the copper pipe at the bottom. This doesn't seem like a standard...
A
The bath taps have 22mm inlets currently the cold water mains 15mm is fixed to the tap by a copper adapter 15mm to 22mm. The hot water is 22mm gravity fed. Is it ok to add a 15mm T to the cold water pipe and then add 22ml adaptor to the T to connect to a 22m TMV . I cannot find any TMValves...
1K
I have a home with an oil boiler in a garage turned into a flat, heating both flat and main house, running c plan with two pumps, two motorised valves simple bi-metal thermostat on wall in flat with 4 standard TRV's rarely used so not worried about the flat, and main house has Nest Gen 3 in the...
Hello, I have just installed a vented McDonald 250L thermal store, it is for multi fuel but currently just connected to a standard oil boiler in the garage which is fully pumped to the TS, the system has two pumps both basic 3speed Grunfoss, one on the boiler return and the other on the CH flow...
1K
Hello, I have quite low flow rate for my electric shower (a piddling 5L/min), and would like some tips or advice about how to solve or find the cause. I would like a flow rate of about 12L/min. Here is my set-up: Standard gas boiler (not a combi) in the kitchen, have cold water tanks in the...
Essaboy
E
