Discuss Purley (CR8) Exposed Shower Valve and other bits and bobs in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Good Afternoon
I have a faulty Triton Petita. This is two years after visit by a Triton bod! I want to replace it with a Mira Element EV which I have.
The supplies to the shower are not balanced as the cold is teed off before the PRV.
Check valves need fitting to kitchen mixer as cold water gets driven into the hot supply.
No maintenance has been done to unvented cylinder since it was fitted in 2014, serving needed?
Dan Kelly has shared 3 photos with you!
All plumbing was done by a plumber.
Reply to Purley (CR8) Exposed Shower Valve and other bits and bobs in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All I had an unvented cylinder fitted about 6 years ago. It only supplies hot water to my shower. I was hoping for a much better flow rate from the shower but it seemed no different from the original combi boiler hot feed. There is (unusually) a lever that lets me select the combi or the...
Steveo111
Hi everyone. I'm installing a walk in shower, opening into shower will be on right, mixer value on right, but shower head and drain on left. The pipe work from the shower mixer valve is exposed silver colour pipework. the pipe work will run up from the valve then take a hard left at the ceiling...
1K
Hi Guy's, Looking for some advice on an issue I have having with a recently installed thermostatic mixer shower in my ensuite. Everything was working fine for a coupe of months however now the valve has started misbehaving which is resulting in having to turn the temperature valve round further...
Hello, and thanks for taking the time to read. I'm trying to work out if the idea I have is practical? The water pressure in my newly renovated house (4 bathrooms is tragic). Current set up is: A hot/cold mixer in the main ensuite which is ok as long as you don't run anything else. One electric...
Hi everyone, Is this set up correct: Attic stop valve turns off the cold water to my bathroom (I think it is the rising main in the attic which I and other residents in the building share as we have shared supply to bathrooms and kitchens) Under kitchen sink stop valve turns off cold water in...
