Discuss pulsacoil 2000 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
N
n.d.b.pluming
Hi has any one worked on this system? I was called round on a job, the owner had no hot water so I checked the whole system out, the small header tank was empty so I refilled it which then got the boiler heating up. There is still no hot water mixing in the exchange unit. The hot feed into the exchange unit is fine, but the cold main feed in is staying cold and is not drawing heat off the hot water side.
The water pump doesn't seem to be flowing I am just wondering if it could be a sensor or circuit board problem as the pump is controlled by the board.
Any help or ideas would be appreciated.
Neill
Pulsacoil Repairs
[DLMURL]http://www.gledhill.net/pdfmanuals/User%20Instructions/PulsaCoil2000%20User.pdf[/DLMURL]
Thanks for the link, but I had already been there and the only thing I could see similar was the exchanger unit might be scaled up which I will check first, everything else on the unit is fine.
They appear to have a lot of common problems.
There is a flow sensor on these that are a comman fault. When mains is run it tells the pump for the heat exchanger to run. Its a screw in sensor and three wires. Easy job. Just make sure you are doing the correct sensor.
Gledhill technical support are very helpful so you can always contact them with any queries.
I'd just like to say we've been having problems with out pulsacoil 2000. Firstly the stat's needed replacing now the pump won't turn off unless the whole unit is switched off. Thanks to this thread I'll ask our plumber to replace the flow meter from the pump, hopefully this will solve our problem, not to mention reduce our electric bill!
Thanks!
Gledhill technical support are very helpful so you can always contact them with any queries.[/QUOTE]
And so they should be @ ÂŁ1 a minute:eek::mad:.
oh yes as i found out recently rip off merchants!!!!
Reply to pulsacoil 2000 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
For reasons that I won't go into. Is it possible to control the water flow to a cold water header tank without having a ballcock in the header tank? ie to place some sort of control elsewhere in the feed pipe before the water gets to the header tank - turning off the mains water supply would...
Hi all I have a problem with my hot water header tank getting warm water into it from the bottom of the header tank (not the hooked overflow/expansion pipe. Hence the header tank then reaches the overflow level and the overflow trickles out. I have changed the ball valve washers thinking it was...
I live in an apartment block where generally hot water is supplied from the communal hot water cylinder and cold water to bathrooms is supplied from cold water tanks in the loft. It is a vented system. However, in a basement flat and a ground floor flat cold water supply to bathrooms is...
I recently installed new hot and cold feeds to a new downstairs cloakroom. After refilling the system the hot taps were all dribbling, spluttering and showing signs of an air lock. I attached cold mains to a hot tap and left it running for 15 minutes, while opening up each hot tap. They all...
We have a gravity fed hot water system in our the house we have just recently moved into. It works fine with the downstairs shower, however we are about to upgrade the upstairs bathroom and are considering installing a shower bath. My concern is that although there is more than sufficient...
