- Messages
- 587
For me the whole fitting is changed. I have rarely used an old nut or olive.
Same more often than not, handful of times with radiagtor valve swaps that I've re-used.
Discuss ptfe tape or no ptfe tape? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
If the valve has been tightened correctly to begin with and not over tightened. The olive should pull off with a bit of persuasionSame more often than not, handful of times with radiagtor valve swaps that I've re-used.
It’s a massive if mate. I end up having to cut most of them off.
Cut it and put a solder coupler and some new pipe on.
I am. I do the workYeah, you're probably right.
I love the smell of burnt lead paint. It smells of victory!Get your blow torch on the paint. It comes off much easier, especially when it layer after layer.
Or round the threads of a union type lock shield valve
Reply to ptfe tape or no ptfe tape? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
