Discuss Proper functionality of a pressure relief valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. Just wondering how a properly functioning pressure relief valve operates.
Does it have it's its own mechanism that detects when the pressure is above 3bar? Or does in rely on the water pressure sensor? The two don't appear to be linked in any physical way.
Also, when a correctly operating valve does 'open', does it release pressure quickly, in a large dump of water. Or does it release the water slowly?
Ta.
Thanks for your reply DuncanM.
Does it release the water in a large 'dump' of water and then close. Or does it release the water slowly. Obviously, if operating correctly.
Thanks again
It will release as quickly as it can until correct pressure tolerance is achieved. May I ask why???
You may
Haha. Our boiler has been losing pressure, quite slowly over a week or so. And then, two days ago, very quickly and the boiler switched off with a E119 low pressure code. I noticed that the discharge pipe connected to the PRV was leaking at a connection. Strange, because ideally there should be no water in that pipe unless the PRV was leaking. I also, noticed that the automatic air valve was, leaking from its plastic headed screw. (It was slightly open). I repressurised the boiler, after which I closed the automatic air valve. I then sat and watched the gauge as the boiler fired up and began heating the rads. I noticed that the needle rose through the gauge quite quickly. In probably less than ten minutes, it was in the red, passing 3 bar, hovering around 3.5 bar. I went outside and sure enough the PRV discharge pipe was leaking water. Quite fast. I think I was expecting, to hear the valve open and dump a lot of water, reducing pressure to a point that the boiler would recognise a too low pressure and subsequently switch off displaying a E119 code.
Thanks for showing interest.
I like a good mystery and like to understand what's happening.
You may
Need a gas engineer in to check something else that’s causing the rapid rise in pressure when on heating.
Yes there are common faults however we can’t discuss them because they are a safety feature of the boiler and we have a no DIY Gas Appliance Stance
Hi shyguy.
May I ask what makes you suggest there is a rapid rise in pressure. How long would it ordinarily take to rise from cold (actually the boiler was displaying water temp at 40c) at 1.5 to 2.5 bar on a properly functioning boiler?
Sorry. Just trying to understand.
My brother was ripped off by a GSE recently. Spent loads of money, without success. When another plumber came, he correctly diagnosed the problem and sorted it in no time.
I don't want to be victim to my own ignorance.
Also, it has been suggested that the expansion vessel may need charging or replacing. Could that be a cause of high pressure? What are the symptoms of a discharged expansion vessel?
Ta again everyones
There should be a steady pressure rise and then fall once heating demand is satisfied. And please know that we aren’t all rip off merchants. I think shyguy is picking up on the fact that the pressure is not being regulated and is able to rise to 3 and above which is a big no no
Thanks Riley.
Two questions if I may.
Could a faulty or discharged expansion vessel be a cause.
What constitutes a steady rise in pressure. 10-15 minutes to reach 2.5 bar?
What actually regulates the pressure? As in, what keeps the pressure at the normal operating pressures. That's a third question
The pressure relief can discharge at any rate but should only do so at 3bar and over.
Issues with the expansion vessel often lead to irreparable issues with the relief valve.
As always faults are best dealt with professionally and quickly to avoid danger and further damage
It could be one of a number of causes yes.
Your second question is how long is a piece of string as everybody has central heating on at different times And there are many factors affecting it such as water temperature, hot water usage to name just a couple. Just know that if your pressure is going above three then you have a problem
Correct system design, incorporating correctly sized expansion vessel
Expansion vessels are for expansion, kinda what it says on the tin.
You definatley need a professional!
Thanks again
It opens at its set pressure, but does not reseat until pressure has fallen a little below. Partly because after llfting there is more area of the mechanism exposed to fluid pressure. Water is released till that lower pressure is reached.
lol one of the reasons why I bought one was the steel hex
I went to Alendorf with Viessmann last year , we stood in awe watching a hollow bar of stainless get bent to a perfect coil with a uniform 0.8 mm gap between each coil . They would not let you video or take pictures.
That's understandable, I gather it's a patented design. It's one of the things that makes their boilers unique. I've been quite impressed with mine so far, but then I've only got an 18 year old Baxi to compare it to. Anything will be a step up compared to that old banger!
Reply to Proper functionality of a pressure relief valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
OFFICIAL SPONSORS
OFFICIAL SPONSORS
