Discuss Problem with a instantaneous gas water heater running a thermostatic shower in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. gort
    gort New Member
    Hi Guys.
    just fitted a thermostatic shower to a Vaillant MAG-sine 250/7 ATZFW H multipoint boiler.
    And it doesn't seem that warm enough, in between the 38% (default setting) and the MAX setting the difference is only 2%.
    Any idea's how I can more heat out of it?
    thanks in advance.
  2. townfanjon
    Is there hot water everywhere else ?
  3. Riley
    I assume you’re meaning °c rather than %. Is your hot water on the boiler turned up?
  4. gort
    gort New Member
    yes, it's 50%c out of the taps
  5. gort
    gort New Member
    It's around 36%c out of the shower, and when I turn the bar shower valve up to MAX it does't make much difference
  6. king of pipes
    More to the point have you adjusted the temperature control as the manufacturers instructions ? all new showers are set to a maximum 42degrees by the manufacturer, if you have hot water everywhere else this could be the problem . Kop
  7. townfanjon
    As above just needs calibrating , read the instructions if you have them
  8. CBW1982
    CBW1982 Plumber GSR Top Contributor!!
    I take it you have fitted it the correct orientation?
    • Like Like x 1
  9. gort
    gort New Member
    I haven't done the installation...got a mate to do it, sorry what do you mean by orientation?
  10. Riley
    Hot left cold right
    • Agree Agree x 2
  11. Gasmk1
    Gasmk1 GSR
    have you considered that there is not enough hot flow through the shower so its modulating down so as not to overheat.
    • Agree Agree x 1
  12. townfanjon
    I have never even heard or seen of one of these lol
  13. Ben-gee
    Ben-gee Plumber
    Is there a button to press on the flow control?
    This limits the flow and can cause this problem as gasmk1 suggests above.
    If there is, press button and fully open valve- if this sorts the problem. Remove flow handle and remove the plastic ‘snail trail’ do the valve just opens fully without the button needing to be used.
    • Funny Funny x 1
  14. Gasmk1
    Gasmk1 GSR
    i have seen them but a long time ago not many fitted, i dont think they make them any more unless for the european market
    • Like Like x 1
    • Informative Informative x 1
  15. gort
    gort New Member
    thanks guy's,
    I've got it warmer by turning up the boiler....now... why didn't I think of that.
    • Like Like x 1
Loading...
Similar Threads - Problem instantaneous water Forum Date
Bathroom Floor Tile Problem Bathrooms, Showers and Wetrooms Yesterday at 10:56 PM
Pump on return is there a problem? Central Heating Forum Jul 8, 2019
