Hello again. I've now had multiple plumbers as well as Thames Water come in and have a look and it's only confused me more.
The pressure at the water meter is 3.5-4bar with a 20l/min flow rate. The pressure at the outside tap is 3-3.5 bar with a 20l/min flow rate. We couldn't get a pressure gauge to fit on any of the inside taps, but the flow rate in the kitchen is between 8 -10l/min and in the loft it's about 13l/min. I have a new Megaflo in the garage and the plumber who installed it has told me that all the pipes coming from the Megaflo are 22mm ones.
I have new plumbing and new Hansgrohe fittings in both the first floor and second-floor bathrooms and the fitter has assured me that all the pipes he's used are also 22mm ones, that connect to 15mm ones just before they connect into the shower/etc.
It seems like the water pressure & flow are both good at the water meter as well as at the outside tap, but both drop significantly inside the house.
I've had a few people suggest I change the mains pipes to 32mm blue pipes, but I don't see how that would help considering the fact that despite the old pipes, the water pressure at my outside tap is excellent.
I've also had plumbers suggest the break tank/booster pump solution but no one can seem to work out what the issue is and therefore the solutions they suggest feel like guesswork.
Has anyone had anything like this before? Any idea why the water flow and pressure is dropping so much and what I could do to fix it?
@Vee @ShaunCorbs ?
@Vee @ShaunCorbs ?
